Technical 283 SBC draft tube
Discussion in 'Traditional Hot Rods' started by Timothy Murphy, May 30, 2024.
  1. Timothy Murphy
    Timothy Murphy
    I have an early 283 with the draft tube opening in the block. I want to cap off this opening ( have a vented oil fill tube). What have you used to block this opening? I do not have the fitting shown in photo. Photo was found on line. Thanks.
  2. jaracer
    jaracer
    If you cap it off, how are you going to vent your crankcase? Are you installing a PCV?
  3. squirrel
    I just bought one of the fittings that covers the hole and has a 1/2" hose barb, to connect to the old screw in type PCV valve. It seems to work.
    You could also just put a freeze plug in the hole in the block, and get valve covers with holes for breather/pcv
  4. I’m gonna run an original one of theses
    alanp561, X-cpe and vtx1800 like this.
  5. squirrel
    that's the one I got...
    anthony myrick likes this.
  6. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Define “cap” the hole.
  7. DDDenny
  8. From another thread
  9. WashBear2
    WashBear2
    But draft tubes make your floorboards last longer!
