283 V8 rebuild
Discussion in 'The Hokey Ass Message Board' started by welditall, Mar 7, 2009.
  1. Roothawg
    Roothawg
    700R will be at least double the cost (if not more) of the TH-350. Just a thought.
  2. parksquijada
    parksquijada
    from norcal
    Trade that 283 to me for my 350 and you'll get better mileage just because the motor wont strain so much. Have a 350 turbo also. Heck for 2 grand ill build it with an rv cam. Pm sent
  3. 36tbird
    36tbird
    I got a 283 in my '36 Ford Sedan with a TH400 behind it (hey, it was cheap and available at the time.) 2.88 8" rearend and a 650 Edelbrock rebuilt to resemble a 500 (was cheaper than buying a 500 outright). I get 21 mpg with that old car.
    I got another 283 that I'm going to rebuild with a 200r4 for my '40 sedan delivery 'cuz I kick myself for taking the above motor and trans out of it in the first place to get the '36 going.:cool:
  4. nick_s
    nick_s
    from Ohio
    Not if you find a nice used one out of a 87-93 Camaro or Caprice. There is a guy in FL who sells them for $250 tested and all w/ convertor. Would work fine behind a 300 hp small engine.
  5. Shaggy
    Shaggy
    from Sultan, WA
    I love the 283 in my OT daily, short on torque, but for work and back it's great, fast enough but wish it was faster
    450cfm holley
    I was told "RV" cam
    305 heads
    weiand intake
    headers
    Gets over 20 MPG in a beater 81 el camino with a shift kited T-400, i picked it up minus carb for $250 with 40,000 miles my only real problem is the 2.73 rear ****S, cuz it needs more RPM's
  6. PurplePearl50
    PurplePearl50
    from Sedalia,Mo
    Filled mine up today and it came out to 26.9 MPG....283 with a small cam and auto with some high gears and your set.
    It aint about getting there faster than anyone its about getting there in style...
  7. Shaggy
    Shaggy
    from Sultan, WA
    Remember on the 283's they are small motors, Dont put a BIG carb and intake on it, your usable RPM range will go WAY up, and they have a small stroke, so they LIKE rpms to make power
    I had stock 305 running the same intake and carb in my '81 EC before, Lots more torque, but NO rpm, whereas the 283 loves Rpms but is a little fussy off the line. They are total opposites
  8. hipkatgreaser
    hipkatgreaser
    I've got a 64 4 door belair with 327, rv cam, edelbrock rpm intake, 650 holley vac secoundaries, 700r4, stock rear end, use as daily driver, good power and averages about 18 mpg - 23 mpg. solid car I would never go to turbo 350. You can find the right deals for a good 700r4. check junk yards and internet
  9. JackdaRabbit
    JackdaRabbit
    from WNC
    What ****gy said!
    I just sold off my (not OG anyway) 283 that was in my 63 C10 to a guy doing a 57 BelAir resto.
    I freshened up a roller cam 305, LT1 cam, Eddy intake and 500cfm 4bbl, T5 and 3.73 rear because I haul and tow stuff sometimes and I'm almost never a wring-it-out driver. I'm hoping for good MPGs but I won't know `til after the break in and tune.
    It depends on your vehicle, driving style and needs. If it's a SBC it can't be all bad.
  10. 56sedandelivery
    56sedandelivery
    All the X-frame cars used a SHORTER version of the Powerglide at 25 inches long as opposed to 28 inches for the short shaft TH350 and 200R4 transmissions; the 700R4 is even longer, as is the TH400. You WILL have to SHORTEN the driveline to use ANY trans other than the original Powerglide. TH350 will be the cheapest route other than keeping the Powerglide. You probably have low 3 series gears, and an overdrive trans behind a 283 with that high of gears won't make for the best combination; the engine will lug with the trans in overdrive. JMO. Butch/56sedandelivery.
  11. three year old thread.....and the original poster hasn't been here in two years
    i hope he got it figured out by now
  12. 3wLarry
    3wLarry
    from Owasso, Ok
    changed it for you...:)
    kidcampbell71 likes this.
  13. thank you....my internal clock must be off
