okay..what I have done..checked coil and alternator..all good. replaced fuel filter and fuel pump. There was a small va*** leak at the front of the carb. fixed that. pulled out the needles on the front of the carb and blew carb cleaner through them. It is a little better now but still a little rough. When i give it some gas and raise the rpms in park it kinda bogs every 5 to 7 seconds for just a blip...bad accellerator pump in the carb maybe?? also the the needle on the driver side is unresponsive. I cant raise it and lower it all the way in both directions and it does not affect the idle...carb problem or a vacuum leak i missed somewhere???
