29 ford Brake issues...
Discussion in 'The Hokey Ass Message Board' started by miller 38, Apr 16, 2012.
  1. miller 38
    miller 38
    from illinois
    I have a mostly stock 1929 ford model A truck, and want to convert it to disc brakes. What is the easiest and or cheapest way to do so... speedway has aconversion kit for 37-48 ford spindles but also sells a 28-48 ford spindle. Is this a typo or will the 37-48 brake kit work on my original 29 spindle.
  2. 31Apickup
    31Apickup
    This question pops up on here quite a bit, you can do a search. There isn't a disc brake kit for the model A spindle. If you are keeping it traditional with the banger, you can easily convert 39-48 hydraulic drum brakes with a readily available spacer kit. They will stop it really well.
  3. Flatheadguy
    Flatheadguy
    The reply by 31Apickup, above, is right on the money for ease of conversion and to also retain a somewhat traditional appearance. Don't think in terms of stopping power. I don't think you are planning a Hemi engine swap in the nerar future? (smiling) Drums on all four work just fine. Master cylinder/mount and so on....
    Speedway is a great source.
