Projects '29 Ford Roadster PU Project - in progress
Discussion in 'The Hokey Ass Message Board' started by psycho666, Dec 31, 2008.
  1. SPEEDBARRONS
    SPEEDBARRONS
    is the old rear end, the wide five..is it a 3/4 axle? if so I could use it
  2. onemintcaddy
    onemintcaddy
    MAN,,, Theres nothing COOLER than a Chick welding,, An doing a dam good job at it. Very nice work and VERY consistent on your progress. Thanks for all the detailed pitchers. Keep it up,, :D
  3. 60'shotrod
    60'shotrod
    Lauren, Damn GOOD welding for anybody I reckon!:D:)
    Nick.
  4. gup
    gup
    from Washington
    Damn Lauren, your kicking as on this ride!! Keep it up and I'm sure you will make it to Billet Proof.
  5. psycho666
    psycho666
    from Wa
    UPDATE
    to use an open drive banjo center with 1936 axles and axle bells.....
    you have to press off the taller open drive inner bearings and press on a set of shorter 1936 bearings - 5.28.09
    filing down the 4 main points on the pitman arm 5.28.09
    did some more welding on the cab today as well...but it would've just been more redundant pictures....will post when it's finally welded up.
    more work tomaro and through the weekend...
    lau
  6. hellrod666
    hellrod666
    from seattle wa
    Scott Lauren is using parts off each axle.... the bells and the axles out of the 36 and the open drive center out of the late truck rear. But let me know what you need and i may have parts or a axle for you.
  7. 60'shotrod
    60'shotrod
    Lauren, you are fast becoming an expert on Hot Rods and I mean that in a GOOD way!
    Nick.
  8. psycho666
    psycho666
    from Wa
    UPDATE
    everything torn apart . ahhhhh 5.30.09
    welding up the last bits on the frame 5.30.09
    inner axle bearing race from inside of axle bell that's pitted 5.30.09
    new inner axle bearing race! 5.30.09
    it's getting there...
    L
  9. spence-d
    spence-d
    Even though your RPU has seemed to explode into a million pieces - its all down hill from here.........
    Spence.
    p/s.... you look ridiculously comfy behind that welder :)
  10. Floorboardinit
    Floorboardinit
    Hot damn, thats a good lookin' weld! Johnny
  11. 60'shotrod
    60'shotrod
    Lauren, Now you're gonna see the light at the end of the tunnel!
    Nick.
  12. This is great and looks good! For me, part of the adventure is the learning process. Self reliance! Can't wait to see the pics after your first outing - when is the ETA?
    I picked up a copy of Emersons essay "Self Reliance" for inspiration and this is what he is talking about..............
  13. psycho666
    psycho666
    from Wa
    thanks guys.
    my ETA is June 27th. hoping to make it to Billetproof this year - we'll see what happens.
    more pictures to follow later...
    Lau
  14. Hot Turkey
    Hot Turkey
  15. hotrd32
    hotrd32
    from WA
    Oh, to be young again! I can't wait to see you driving that ....and I can't even imagine how happy and proud you are going to be......you are a Hot Rodder!
  16. Royalshifter
    Royalshifter
    Moderator
    That is coming along real nice.
  17. psycho666
    psycho666
    from Wa
    UPDATE
    grinding off welds on cab 5.31.09
    bolting in k-member for the final time 5.31.09
    welded in front body mounts for support 5.31.09
    cleaning out the bearing carrier and the spider gears & axle 5.31.09
    frame all welded up and the engine back in place 5.31.09
    all for today...more work tomaro. leaving on Thursday for Michigan.
    Lau
  18. Mark and I got that engine in there just in time for your pictures! :)
  19. psycho666
    psycho666
    from Wa
    :) Thanks Keith & Mark
  20. 60'shotrod
    60'shotrod
    Bloody Hell Lauren! I can't keep up with this thread, you're workin' TOOOO fast!:DStunning welding too!
    Nick.
  21. Shaggy
    Shaggy
    from Sultan, WA
    There are a couple different angles on diff gears on the ends of the axles as i recall,
    So if the spider gears arent the originals with the ends of the axles they might not mesh proper
    Mark probaly already knows that, but figured i'd mention anyway just incase
    Good luck!
  22. psycho666
    psycho666
    from Wa
    UPDATE
    rear-end completely put back together. 6.1.09
  23. 60'shotrod
    60'shotrod
  24. Lauren, your rear end looks good LOL :D
    Get er going. I'll have my roadster at Billetproof now, too. Not that you care, but, whatever ;)
  25. psycho666
    psycho666
    from Wa
  26. hotrod-40
    hotrod-40
    Hey Lauren,
    I don't know if Mark told you, but I just picked you up a Fluke volt meter. It's a good tool to have. I will just give it to Mark.
  27. Did you get me one asshole?
  28. hotrod-40
    hotrod-40
    ya, but yours has a little fire damage. I hope you don't mind if half the buttons are gone! We'll get together... You know what I mean!
  29. psycho666
    psycho666
    from Wa
    ha thanks! Billetproof Michigan tomaro boys!!! i can't wait...
  30. just found this thread again. pu is lookin great. checked out your tattoos as well. guess the pu is almost done? 27th of june aint far away.
