Projects '29 R.P.U. Build
Discussion in 'The Hokey Ass Message Board' started by Mark H, Oct 5, 2009.
  1. WhiteDevil
    WhiteDevil
  2. Farmer
    Farmer
    nice looking build there dude- i did one a few years back, only a '28. Fun aren't they? Keep it going!
  3. Mark H
    Mark H
    from Scotland
    WhiteDevil/Farmer,thanks guys.I've started putting it back together,hopefully have an update this weekend.
  4. Mark H
    Mark H
    from Scotland
    As promised,I have a brief update.
    Started putting it back together today.Just got to fit the rear right brakes and axle and it's a roller!Today is the first time it's sat on it's Firestones.
    When I was sorting out the parts,I had to move my Walker Radiator.Lifted the lid of the box and out jumped half a dozen mice!The *******s had made a nest in the foam packing.
    The steering box mount has now been fully welded and dressed,I'm pleased with how it came out.
    When sorting out the parts for the rear end,I realised that there were no bearing retainers with the axles as it was diss***embled when I got it.So,I made a pair from steel plate.
    Next job is to finish the rear brakes then fit the engine and box.
    Hot Rod Hayride,here I come!(With a bit of luck!)
  5. 60'shotrod
    60'shotrod
    Mark, Outsatanding!:D:)
    Nick.
  6. Mark H
    Mark H
    from Scotland
    Cheers Nick.Got the other side done this afternoon,now officially a roller!
    Also fitted the radiator to the grille shell.Those ****in' mice have eaten through the overflow tube:mad:.And it was covered in mouse piss:mad:.
    Going back over shortly to get a start on fitting the motor.
  7. 60'shotrod
    60'shotrod
    Mark, Maybe the mouse piss will help aid the coolin'!:D:D:D;)
    Nick.
  8. Mark H
    Mark H
    from Scotland
    Ha Ha!Possibly Nick.Probably make it smell like a *****s knickers too!:D:D
  9. 60'shotrod
    60'shotrod
    Mark, HOW do you know this, did you add the word 'probably' as an after thought?:D:D:D:D:D:eek:;):p
    Nick.
  10. Dreddybear
    Dreddybear
    Lookin good man!
  11. Looks great. Me loiks what yer doin'. Hot rodding seems to be a universal language.
    Maybe the spreading HAMB gospel could bring a little world peace.
  12. Mark H
    Mark H
    from Scotland
    Thanks seesko.
    World peace would be nice but,we'd probably end up fighting over who gets the early Ford tin!:D
  13. striper
    striper
    Tilt column, 1930s style. Looks like a quality build....or is that "proper job"?
  14. Mark H
    Mark H
    from Scotland
    Thanks striper,much appreciated.Hope it turns out as nice as yours!
  15. Or what's the right engine:D.
  16. Mark H
    Mark H
    from Scotland
    Got the engine and box fitted today,with the new engine mounts.Plenty of clearance around the steering box too.You'd think I planned it that way!:D
    TECH TIP!If you're using a small Ford in an 'A' or other small car,swap the stock oil filter (5 inch long) for one from a 4-cyl Pinto,Motorcraft EFL-90 or equivalent.It's a direct replacement and is only 3 1/2 inch long.Using this filter, the motor fits between the frame rails with room to service the filter.
    Also got my home made ladder bars mocked up.Not decided on the design for the stiffener yet but,I'll get round to that later.Before I fit them,I want to raise the rear about 1/2 to 1 inch so that all the rake is in the rubber.
    Mark
  17. 60'shotrod
    60'shotrod
    Mark, GREAT progress, the engine mounts look ****** Spot-On!
    Nick.
  18. Martin_F
    Martin_F
    Looks nice!
    I'll be building my own ladder bars this weekend, so I looked closely on yours ;)
    Are you using the 5/8 clevis on the ****** side too??
    Did you use 7/8 OD DOM tubing?? That's what I ordered mine. They're high, but I'd rather have the stronger stuff, if you know what I mean...
  19. Malcolm
    Malcolm
    from Nebraska
    Looking good, Mark!! I like lots of your details so far... will keep an eye on this thread.
    Thanks for posting!
    Malcolm
  20. Pinstriper40
    Pinstriper40
    Sharp! can't wait to see more progress!
  21. Mark H
    Mark H
    from Scotland
    Thanks Nick and fuxl.
    fuxl,yes it's 7/8 inch CDS(cold drawn seemless)which I guess is the same as DOM.
    The front of the bar is fitted with an adjustable polyurethane bushed rod end,5/8 inch thread.
    I realised after I'd bought the clevises,rod ends and tubing,that I could have got a ready-made set a lot cheaper!You live and learn,I guess.:)
  22. Nice so far! Can you shrink the first series of pics so we can see them without scrolling up and down?
  23. Martin_F
    Martin_F
    Thx Mark!
    I've seen the kit for 350+ Bucks... tubing is about $230 but I can make it to the perfect length!
    Keep us posted, like to see how yours turns out!!
    Actually, I like the first ones better :D
  24. Mark H
    Mark H
    from Scotland
    Malcolm,Pinstriper 40 and Richard D,thanks for the positive comments,much appreciated.
    I don't know if the first pictures can be re-sized after posting.Thankfully I now know how to do it BEFORE posting!:D
  25. Chris5.7ltr
    Chris5.7ltr
    Loving those engine mounts, I have a 351 Clevo in my Pick Up that I'm building but have never really been happy with my mounts and wondered how doing them this way would work.
  26. Mark H
    Mark H
    from Scotland
    Hi Chris.These are the second set of engine mounts I've made for this car.The first set did the job but were fugly!
    The new set are much better looking and were easier to make too.
    The top plate is just 1/2 inck steel drilled and cut to shape,early Ford style rubber doughnut in the middle and the lower part just 1/4 inch steel.
    I just messed around with cardboard templates for a while to see what looked o.k.
    Cheers,
    Mark
  27. 29paul
    29paul
    Good looking hot rod
  28. Like that 289 sitting there. Those valve Cal Custom Valve covers are so cool.
  29. Mark H
    Mark H
    from Scotland
    Thanks 29 paul.
    seesko,thanks.I was originally going to use the stock factory valve covers but these came along at the right time/price!Two of the fins are damaged at the rear of one,no big deal.
  30. Mark H
    Mark H
    from Scotland
    Fitted the rad today to check clearance etc.Couldn't resist throwing on the cowl and hood for a sneak peak!
    Hood's a little out of shape but fixable.
