Projects 29 roadster highboy build
Discussion in 'Traditional Hot Rods' started by kracker36, Feb 11, 2016.
  1. Well I got a real soft spot for a high boy roadster. For some reason in my minds eye roadsters look best as high boys and coupes and sedans should be channeled. Yea, yea lame as hell but I call it the way I see it.
    Anyway you can't go wrong with a high bot roadster.
    I have been a fan of the Y block about forever, but I would not discount the 260 V8. I have not seen a 260 powered hot rod since about the '60s that I recall, they are cool little motors and in good shape even stock push a light car along real well.
  2. kracker36
    kracker36
    I agree on the y block option as far as it is more appropriate for this car. I also have a few FE goodies in the shop too, so its an option as well.
  3. kracker36
    kracker36
    The only issue with my 260 and my weiand timing cover is the use of an electric water pump. Not crazy about that in this car
  4. LOL its a sprint car option, back it in baby. :D
  5. kracker36
    kracker36
    How about an option for a fan?? Lol
  6. Well I like the little fold up ones that you get in China town, but a lot of mid westerners prefer those big ol Baptist fans like you get at the tent revival. :D
    I guess that if you were running an electric pump an electric fan would definitely be in order. LOL Never really thought about a fan with an electric water pump, but there has to be a 20 dollar cure for this 10 cent problem. ;)
    gwhite likes this.
  7. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    If ya want to run a 39 ****** with the 260 I have an adapter for that!!
  8. Atwater Mike
    Atwater Mike
    @Kracker...Speaking of the 'Merc stuff', I bought a '63-1/2 Merc Marauder 390 engine, has round top stamped steel valve covers, with MERCURY stamped prominently atop.
    My son and I came across some 'Poverty Caps' with MERCURY stamped in them, (Mehnonite folks order cars with no options around here, so there are some in wrecking yards...this Merc was early '70s. Never saw a 'baseline Merc', they are a step above Fords and usually ordered with all the 'trim'...)
    There was a place to get a shortened SBF water pump in the '80s-'90s, seems that somebody offered a whole kit, pulleys, bracket to shorten the lengthy front by 1.5".
    Street rod guys were all over 'em, I saw a neat '25 T sedan with the setup. Engine was firewall-tunneled, but not near as far as it would have been with the 'snub nosed pump'!
  9. woodhawg
    woodhawg
    Not sure if you are running fenders and hood, but my 28A on a 32 Frame the regular water pump and Ford fan fit with moving the radiator forward an inch or so. 32 frame is longer.
  10. kracker36
    kracker36
    Cant run a standard water pump with my timing cover.
  11. woodhawg
    woodhawg
    I love that cover, very few people have those or has even seen them. The electric water pump will work just fine.
  12. sanfordsotherson
    sanfordsotherson
    from So. Cal.
    “Well I like the little fold up ones that you get in China town, but a lot of mid westerners prefer those big ol Baptist fans like you get at the tent revival.”
    Ha! That's funny!
    I dig '29 Roadsters on Deuce rails. Looking forward to watching this one develop...
  13. kracker36
    kracker36
  14. kracker36
    kracker36
    Not a great pic, but worked hard to box frame and install rear x member. Finally sitting on the frame with NO gap!
    Front wheels are 16x3.5" v8/60s. Rears 16x4.5s.
    VonKool13 likes this.
  15. wheeldog57
    wheeldog57
    Man, that SW gauge panel is wicked!
  16. kracker36
    kracker36
    Studebaker 289 just entered to mix!
  17. Roadsir
    Roadsir
    Nice job, I've recently gathered a pile of roadster body parts, 32 frame, axle, spindles.....I'll be following the build.
  18. chopt top kid
    chopt top kid
    Good start! I've got a thing for model A's on '32 rails also...
  19. piker
    piker
    The Brookville will save a lot of time on body work. I put mine on an original frame that was pinched in the 50's(a little too much) but it worked out ok. I also went with the Merc caps to be different. They are somewhat hard to find.
  20. kracker36
    kracker36
    Well, got a bit of news! Committed to a 289 studebaker this week. Got a 289 with an Edmunds 2x2 i take. I normally keep Fords in Fords, but this is going to be cool anyway.
  21. kracker36
    kracker36
    Dropped of 40 spindles to have new bushings honed. Priming 53 backing plates and hubs
  22. kracker36
    kracker36
    Truck load of 289 studebakers!
    Stovebolt likes this.
  23. Roadsir
    Roadsir
    You have the market cornered on baker parts for sure......
  24. i am follow your treat :)))) i like your ideas
  25. kracker36
    kracker36
    Both of the blocks that I checked are standard bore. Now I have to decide on which trans to run behind it.
  26. big duece
    big duece
    from kansas
    I like where your going with this, keep up the great work.
  27. wicarnut
    wicarnut
    Nice Work ! Admire your skills
  28. Love the timing cover on the 260. There was an article in Hot Rod years ago that used a water pump from a Detroit 4/71 -6/71 series diesel. They placed it low and close to the block on the right side, fabbed the bracketry and an end plate with a bung welded to it for the return and plumbed it with an10 hose to a timing cover just like yours on a SBC. I forget what drive pulley they used, but it was from a domestic car. The pump is very compact.
    On that note, how about a flathead fan bracket/hub off an 8 BA ( late, for the narrow belt) with custom bracket off of the original water pump mounts. I don't like electric fans.
  29. kracker36
    kracker36
    Duncan, i thought about the flathead bracket. Good idea
  30. kracker36
    kracker36
