Technical 29 sedan on 32 rails
Discussion in 'Traditional Hot Rods' started by Crazy8, Mar 14, 2014.
  1. Crazy8
    Crazy8
    from KY
    I am building a 29 sedan high boy on 32 rails and trying to determine what the best look would be for the hood/ front. I am using a 32 grille and running a sbc motor
    The two directions I can go with is
    To run with the same length hood as a 32 and keep the stock fire wall or
    Run the shorter length hood as the 29 and set the motor back into the firewall about 4"
    Thanks
    Jeff
  2. setting he motor back? are you forgetting the wheel base of a `32 frame is longer than a Model A? would you then shorten the frame?
  3. Crazy8
    Crazy8
    from KY
    Yes I would put the front cross member back
