292 chevy 6 just whos running em?
Discussion in 'The Hokey Ass Message Board' started by Eddiesixem, Feb 27, 2008.
  1. Bonehead II
    Bonehead II
    Could someone tell me what the weight of a 292 is and how long are they from the front of the water pump to the rear of the engine block...Thanks
  2. Twisted6
    Twisted6
    The duggan is a 12 port head not a cross flow.the intake entered at angle down into the head the exhaust sat just like it does on a stock head.
  3. 18n57
    18n57
    33" from fan mounting flange on the water pump to bellhousing flange. About 27" from pan to valve cover. Sorry, don't know thweweight
  4. Six Ball
    Six Ball
    from Nevada
    I'm building an injected,turboed 292 now for my 1 ton flatbed. I've got a good running 350 I'll trade for a good running 292. I'm pulling it out of the flatbed! Eddie the info you've here is good stuff the book,the sites,etc. These are torque motors and need to be driven as such,but with some work they can turn some respectable RPMs. As you'll read in Santucci's book Duntov designed the engine and designed in some surprises especially when it comes to using a hybrid head made from 2 V8 heads. You won't want to go there. There is much interchange between the 292 and the smaller 6s and the V8s. There is much that is unique to the 292. Do it ,have fun!:D
  5. tlowe
    tlowe
  6. LB+1
    LB+1
    from 71291
    What kind of porting can you do on the stock head? With out going to the Lump port sit up?
    Do you just V the head bolt casting sitting in the middle?
    I know this a old post but by chance I might get a answer!
  7. 63ChevyII
    63ChevyII
    you might have better luck on inliners.org...
    here's the 292 in my '63 Nova:
    292 L6 Photos
  8. RodNoc
    RodNoc
    from Kelso, WA
    Can anyone tell me what kind of intake manifold this is? Thanks
  9. is that a local rod?
  10. Zerk
    Zerk
    My takeaway is that the pic is of the Mercruiser marine engine twin carb manifold.
    volvobrynk likes this.
  11. Not currently running one but I have run them in the past and was happy with them. I had one in a '41 Chevy truck that just had the common hop up parts that would hold its own. Nothing fancy, a single four, a crane cam (as I recall) and a header all wrapped up in an other wise stock mill.
  12. raprap
    raprap
    from Ohio
    Have a bored and stroked 292 with 3x2, 270 cam and a T-5. Runs like a swiss watch for over 15 years. Gets over 20mpg on the freeway. Smooth, torque monster that is very reliable.
    volvobrynk and kiwijeff like this.
  13. JT Apperson
    JT Apperson
    from va
    I'm building a 292 for my 56 Chevy. .060 over mild cam, Clifford Intake and exhaust. Holley carb. Where do you get the carb linkage for the Holley? Thanks JT
  14. RodNoc
    RodNoc
    from Kelso, WA
    Thanks. I didn't make the connection between the two consecutive posts. Damn meo_O
  15. paintman27
    paintman27
    from new jersey
    well it runs but not in the truck..............
    [​IMG][/URL]
    [​IMG][/URL]
    300 hp @5500rpm
    [​IMG][/URL]
  16. paintman27
    paintman27
    from new jersey
  17. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    That is SWEET!
    Looks like Tom Lowes pieces, right?
  18. raprap
    raprap
    from Ohio
    I got the linkage kit from Langdon's.
  19. coupe33
    coupe33
    I spent a lot of effort on one of these. 292 bored 0.060 over (301) LP Gas pistone (increases compression) lump ported and flow work done with 0.020 shaved off the head. I used the book and asked a lot of questions from different forums. It is still on the engine stand and I still have to do the final head assembly. If I were to do it again I would save a few grand and go with a stocker. Unless you have a dedicated project for it. They are torque monsters no doubt.
  20. edgeabilly
    edgeabilly
    i had a 292, fun motor. All that's left is a Clifford 2x2 intake if anyone's interested.
