Technical 292 inline waterpump
Discussion in 'Traditional Hot Rods' started by cooter1, Jan 20, 2021.
  1. cooter1
    cooter1
    will the waterpump from a 250 bolt on and work on a 292 ?
  2. trucker1
    trucker1
    I think the difference is in the coolant byp*** outlet that can be drilled and tapped on the 250 to match the 292. Someone correct me if wrong. Glynn.
  3. 34Phil
    34Phil
  4. trucker1
    trucker1
    There are two different heights 3-7/8 for 1975 to 1989 292s and 4-9/16 for 1963 to 1974 292s. They used 6 different balancers to juggle belt alignment. Check with Davis speed equipment,com for photos. Glynn.
    stillrunners likes this.
  5. Jethro
    Jethro
    It will physically fit but the impeller on the 292 is slightly larger. There will likely be a difference in flow , may cause overheating problems.
  6. cooter1
    cooter1
    ok . thanks . its going in a car . it should cool fine .
