Customs 292 noise
Discussion in 'The Hokey Ass Message Board' started by martinb, Feb 27, 2021.
  1. Ideas
    1 vote(s)
    50.0%
  2. opinions
    1 vote(s)
    50.0%
Multiple votes are allowed.
  1. martinb
    martinb
    Hello gear heads, I'm new here but have visited many times, I have a question about piston slap or perceived piston slap, recently overhauled 292 is making me noise and I notice if I plug the breather at the valve cover and leave the pcv valve connected the noise changes. Any ideas.?
  2. squirrel
    post a video, so we can hear it.
    What all was replaced during the overhaul? And what was done to the bores?
  3. FrozenMerc
    FrozenMerc
    Got to love FNG's. Post a question to the wide internet about a mysterious noise with a twit length description. No pictures, no videos, no details what so ever. Didn't even indicate if it was a Ford or Chevy 292, let alone build specs, clearances, etc. He could have a tiny elephant living inside the oil pan and breaking wind for all we know.
  4. Wrench97
    Wrench97
    Single post so he's going to have to make several more in order to attach anything.
  5. 55blacktie
    55blacktie
    Aren't we cheerful!
    loudbang, Sonofabob and squirrel like this.
  6. 302GMC
    302GMC
    from Idaho
    Golly, frozeguy ... somebody **** in your mess kit ?
  7. 55blacktie
    55blacktie
    We've probably heard the first, and last, of Newby Martinb. I wouldn't blame him.
  8. Doublepumper
    Doublepumper
    from OR-WA, USA
    A little rude...but I thought the elephant thing was kind of funny.:rolleyes:
    Martinb, if you haven't bailed yet, do as squirrel suggested. Someone here will be able to narrow it down for you but, without more info it just turns into a guessing game.
    Good luck!
  9. martinb
    martinb
    Sorry about the delay we had birthday party for our 4yr old grandson here. YES ITS A CHEVY INLINE6 .040 OVER STANDARD RODS AND MAINS ,REBUILT CYLINDER HEAD , WITH STEEL SHIM HEAD GASKET PRETTY MUCH ALL STOCK EXCEPT MILLED THE STOCK INTAKE FOR A ROCHESTER 2BBL . OIL PRESSURE IS 25PSI HOT IDLE
  10. martinb
    martinb
    BTW, the noise changes ,almost goes away, if I plug off the breather tube and leave the pcv hooked up to valve cover, could the pistons be backwards?
  11. Wrench97
    Wrench97
    Other then the rpm changing when you plug the breather I can't see a reason that would make the noise stop.
    Does it go away with rpm change?
  12. egads
    egads
    Not being able to hear your noise, when you close off the breather you are creating a large vacuum inside the engine. See if any tin is moving , oil pan, valve cover, side covers, timing cover ? ( Don't worry about at***udes here, most are pretty grumpy lately:):) )
    Irish Mike, senginc and garyf like this.
  13. Martinb, I am glad that the mouthy people didn't drive you away, as you came back with more information about your engine noise. Just bear with it, and you will eventually get the information / help to answer your questions.
    tractorguy and egads like this.
  14. martinb
    martinb
  15. martinb
    martinb
    I've been trying to post a video clip of the sound but it keeps saying: there is no extension?
  16. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Ever hear Mom yell "CLOSE THE DOOR YOUR MUSIC IS TO LOUD!!!!!!" Ya it's a thinker.
  17. martinb
    martinb
  18. martinb
    martinb
  19. Mr48chev
    A Mechanics stethoscope is a real good thing to have chasing down noises and knocks. About 10 bucks at the parts house and you put the tip of the probe on various spots on the engine until you figure out where it is coming from as close as possible.
    If you pull one plug wire of at a time while it is running you can usually tell if you have a problem with a piston. I use a pair of what I call "chicken plyers" = insulated pliers for pulling spark plug wires off plugs when the rig is running. If it has points rather than Hei it might just give you a jolt rather than knocking you on your **** though.
    Keep us posted on what you find and it's always good to post what exact engine you are working on from the get go, A lot of Ford guys think the only 292 around is a Y block. Even had one ask why I was putting a Ford engine in my 48 when I told him I had a 292 for it.
  20. martinb
    martinb
  21. martinb
    martinb
  22. martinb
    martinb
  23. martinb
    martinb
  24. martinb
    martinb
  25. martinb
    martinb
  26. Wrench97
    Wrench97
    Try using a test light, keep the pointy end near the end of the wire as you pull it off the spark will jump to the test light probe and not your fingers :)
  27. Wrench97
    Wrench97
  28. martinb
    martinb
    I've adjusted 2 times, once with engine off rotate engine till rocket is up and rotate pushrod to confirm base of cam then 1 turn in on adjuster. also tried engine running loosened till I heard tapping then tighten 1 turn after noise went away. what gets me is the change in noise when vacuum is applied in crankcase from pcv
  29. Wrench97
    Wrench97
    With them running I always went 1/2 turn after it stopped clacking, 1 turn should not make a noise though.
    Does the sound go away if you lower or raise the rpm?
    Is there a heat riser ****erfly on the exhaust manifold?
    As posted above try pulling 1 plug wire at a time to see if one not firing makes the noise go away.
  30. martinb
    martinb
