2gc help
Discussion in 'The Hokey Ass Message Board' started by Karmaize, May 17, 2016.
  1. Karmaize
    Karmaize
    from Mass
    I have a Rochester 2gc I need help identifying the right hand side port on this carb. I know the left side in this picture is fuel inlet. The right side port I have blocked off but can figure out if it need to be hooked to vacuum or if I can leave it plugged off. Thanks in advance for the help.
  2. sunbeam
    sunbeam
    It's a float bowl vent don't block it off. Early carbs just vented it to atmosphere yours was hooked into a charcoal canister system.
  3. Yep ^^^^
    If the fumes bother you run a line down to the pan rail. or into the fender well.
  4. Karmaize
    Karmaize
    from Mass
    Since I have it blocked is that possibly causing my off idle stumble?
  5. 57 HEAP
    57 HEAP
    Not likely. But you might "run out of gas" before the needle valve opens.
  6. aaggie
    aaggie
    I used to put a disposable plastic fuel filter on it so it would still vent but wouldn't inhale any underhood dirt.
