2x4 aircleaner setups.......
Discussion in 'The Hokey Ass Message Board' started by 5wbomber, Dec 11, 2007.
  1. 5wbomber
    5wbomber
    i just got an awesome edelbrock 2x4 setup for the coupe........and i am thinking about making an aircleaner for it(old finned belt cover for a bug...) but i wanna see what you guys have done or seen..... thanks,i dnt wanna see some billet mess...........
  2. mines just a standard 2x4 finned scoop, nothing creative here, move along.
  3. Da' Bomb
    Da' Bomb
    I'm using a Caddy air cleaner housing with a14" air cleaner sitting on a 1/4" aluminum plate, round, of course to match.
    Pat
  4. Twisted6
    Twisted6
    I just welded two round ones together and i did the same for my 3x4
    set-up. But i am working on a Billet on now.Finding a filter for it when I'm done maybe interesting.
  5. drhotrodmd
    drhotrodmd
    I used the same setup on my 29 and modified some aftermarket 57 Vette air cleaners to work.
  6. I run the tallest air filters that go under my hood.
    Just don't backfire the engine... the foam in these won't take it.
    -bill
  7. tommy
    tommy
    Ya can't talk about dual quad air cleaners without mentioning these. Specially adapted late 50s hot rod air cleaners for the Chevy 270 set up. I've always loved these things! If I ever found a nice set, I might have to build a car around them.:D
  8. Royalshifter
    Royalshifter
    Moderator
  9. old kid
    old kid
    from middle ga
    these are repops from wolk design.
    dan
  10. DualQuad55
    DualQuad55
    from NH
    Here are my air cleaners on the 401" Nailhead in my '55 Buick .
  11. Sloppyseconds
    Sloppyseconds
    from Pasadena
    Dude those things are SICK!!
  12. DualQuad55
    DualQuad55
    from NH
    well, it is cold and flu season...
  13. man o man, after seeing this thread, I feel lame and not worthy.
    I needs to do something different.
  14. Larry T
    Larry T
    It's a "store bought" set up, but I like it.
  15. seymour
    seymour
    from PNW
    Don't be silly.... they're all over...:p
  16. seymour
    seymour
    from PNW
    **** those are nice! The repops just are quite right. What are those small base 4GCs off of? 303 Olds? For some reason I didn't think the inlet cleared the front carb...
  17. Lee Martin
    Lee Martin
    ....by O'brien Truckers:
  18. elcornus
    elcornus
    Here's my junk.
  19. Tinman
    Tinman
    from Orange, CA
    ^Word.^
    ...the O'Brien Truckers unit, I mean.
  20. SinisterCustom
    SinisterCustom
    Cal Custom 40-40's and Nicsons.....
  21. HEATHEN
    HEATHEN
    from SIDNEY, NY
    They probably don't breathe worth a ****, but I love those old Cal Customs with the metal element with "V8" shaped openings.
  22. DualQuad55
    DualQuad55
    from NH
    I like the V8 pattern 'grills' as well, but on the Edelbrock intake for the Buick, the carbs are SO close together there is no way to use them. I couldn't even use the other type with the flat side pointing towards each other. Now if I could find a couple of the V8 type cheap for the 2x4 322 motor I am getting ready to do....
  23. buzzard
    buzzard
    Alliance Member
    The down side of the Edelbrock manifolds is that they put the carbs real close together. (at least, my C26 does) A lot of the cool dual round cleaners won't work. I used Cal Custom 40-40 scoops on my, with risers so they sit kinda offset one into the other.
    Sorry for the bad pic. I was taking a pic of the firewall clearance, but you can see how the cleaners sit on the Edelbrock manifold.
  24. DualQuad55
    DualQuad55
    from NH
    Yeah, the carbs are so close that there isn't a 1/4" between the front and rear carb bases. I am sure I could find another setup to use, but with the ones I have, I have no desire to do so. The 322 will use either an Edmunds 2x4 or a Golden Engineering 2x4 ( unless I use a 2x2 or factory X-number 3x2or whatever.) the nice thing about nailheads is there is no coolant or anything in the intake, 8 bolts going straight up and down. You can swap one intake to another in about 7 minutes-less if you put your beer down first.
  25. Chris
    Chris
    I have a pair of these going up for sale....
