Technical 3.31 Shoebox
Discussion in 'The Hokey Ass Message Board' started by robracer1, Nov 14, 2017.
  1. robracer1
    robracer1
    Have a 50 shoebox with stock V8, trans (no OD) and diff with a 3.73 gear.
    I'm thinking I want to put a 3.31 gear in, which is a 51 shoebox with auto trans gear, because at 65 mph I'm turning around 3017 RPMs with the 3.31 I would be turning about 2677 RPMs.
    My Question has anyone tried this, I know One disadvantage is starting from a dead stop up a hill, are there any other disadvantages or problems.
    Thanks
  2. Cosmo50
    Cosmo50
    Why not try a taller tire first and see how it drives?
  3. robracer1
    robracer1
    ^^^^^^^^ I'm running a 205/70/15, 27" tall tire and a lowered rear that's about the tallest tire you can put on the back from what I read from HAMB and other forums.
  4. Cosmo50
    Cosmo50
    I did not know that. Yeah, it looks like you would have to run a 30" tall tire to get that same ratio. The only problem I could see with changing the gear ratio would be your take off and speedometer reading. But those are just minimal problems that could be dealt with.
  5. dan c
    dan c
    speedo gears are available, but with that gear ratio, it'll be a real dog around town. ever look into an overdrive trans. for that '50? the one that fits the '49-'50 seems to be the most plentiful. and you won't be able to recondition that third member--no parts!
  6. oldsman41
    oldsman41
    really you would do better with a od easy to get and rebuild the od . i think your going to fry alot of clutch plates the other way.
  7. robracer1
    robracer1
    May have found a 3.54 ring and pinion, has anyone tried that gear? Don't want to spend the money for a old ford OD system, my plans are to later go with the T5 kit, but for now my 68 year old diff needs some help now !
