3/4" clutch MC autozone?
Discussion in 'The Hokey Ass Message Board' started by hotrodbrad, Jun 11, 2007.
  1. hotrodbrad
    hotrodbrad
    from Tempe, AZ
    Anyone ever gotten their MC from the zone rather than wilwood and others? If so what vehicle were they designed for? thanks
  2. john56h
    john56h
    I have used AMC Spirit/Concorde (1977ish) clutch master and slave. The master cylinder is an aluminum Girling unit with a remote mount reservoir and I think it was 11/16" bore diameter. The slave was a compact cast iron unit...also Girling, but I'm unsure of the bore size.
    You'll also find many of the Japanese cars from the 80s-90s had hydraulic clutch systems too. The slaves looked kind of weak for a V-8 clutch though. Master cylinders would probably work okay.
  3. Phil1934
    Phil1934
    Z car was 3/4" I think. Tilton bolts in place so similar.
  4. hotrodbrad
    hotrodbrad
    from Tempe, AZ
    the amc stuff was more expensive than wilwood! but the z was much cheaper...ill give that set up a shot
    thanks guys
