Technical 3 Deuce Fail ?
Discussion in 'Traditional Hot Rods' started by Vic Walter, Jul 6, 2020.
  1. Vic Walter
    Vic Walter
    Admittedly I am very much a Stromberg 97 / Holley 94 / 3 Deuce carb setup complete novice. It seems to me that carbs should lean forward, not rearward. Only thing that even remotely makes sense is that this manifold is intended for boat use. But what are the options for using it in a car ? It has the expected Edelbrock script and C-357 B.
  2. HOTRODPRIMER
    HOTRODPRIMER
    You are going to have a very aggressive rake.:D HRP
  3. Vic Walter
    Vic Walter
    a- for effort here hotrodmudder, but 44 inch mudders out back and low rider 14 - 650 fronts are not in the planned image
  4. 41rodderz
    41rodderz
    from Oregon
    They have made wedge spacers for these for decades.
    Elcohaulic and Speed Gems like this.
  5. Fordors
    Fordors
    Even with wedge spacers machine work is required to correct the studs. Looks to be 7-8 degrees just to put them level.
  6. I've been on hills with a steeper angle than that. Don't remember the carbs really caring all that much, and if they did they kept it to themselves...
    wackdaddy and VANDENPLAS like this.
  7. Mr48chev
    Looks like an intake for a boat that sets the engine in the boat backwards with the rear of it raised about that much. flathead V drive speed boatr .jpg
    I'm thinking that they ran the prop drive off the front of the crank to have the right rotation for the prop.
    VANDENPLAS, loudbang and big duece like this.
  8. down hill racing?
    Bandit Billy likes this.
  9. Fortunateson
    Fortunateson
    Mill it flat then weld up the stud holes. Then re-drill for new stud holes. Best option is to get a new manifold.
  10. 41rodderz
    41rodderz
    from Oregon
    I had 3x2 flathead intake with those spacers (all vintage) was drilled (only machine work) with Holley 94’s. All good.
  11. Don't think it will make a lot of difference. How the float behaves is the key thing. Easy to check.
    Sent from my moto g(8) power using The H.A.M.B. mobile app
  12. Smiffy
    Smiffy
    I had a manifold like that years ago it was set up for a speedboat not street friendly at all. The time , effort and money involved to build up the manifold or machine it flat isn't worth it. Very strong possibility you could end up wrecking the manifold if you haven't done that sort of work before. Would strongly recommend buying a proper street manifold.
    Gman0046 and loudbang like this.
  13. TRENDZ
    TRENDZ
    If you have access to a mill, rough mill it flat, drill and tap the holes for 3/8” pipe. Get some square drive pipe plugs, loc***e them in. Finish mill the entire surface, and re-drill and tap the holes at the correct angle.
    Welding the holes would work, but machining after welding doesn’t always go so well, as the material is now soft in the area.
    The pipe plug trick works really well for correcting damaged/ mis-placed holes.
    trikejunkie and harpo1313 like this.
  14. Vic Walter
    Vic Walter
    Thanks for all the suggestions.
    Mr48chev is most on it. Some boats running a "V" drive have the engine mounted water pump forward, angled down in front to allow a short shaft attached to the harmonic balancer to the V drive, second shaft from the V drive out the bottom of the boat, under the oil pan, to drive the prop. I guess this is common in flat bottom performance boats.
    All this is well and good, but now, what to do about it ? Boat guy I spoke with says finding a boat guy that wants it is rather remote, ebay would offer the best chances.
    Machining the mounting surface flat or some angle forward will work, there is enough meat to get this done. But welding up the holes and re tapping is less desirable. Solid aluminum pipe plugs are available and will hold a thread much better. So I think the loc***e / epoxy is the better option and I do know a guy......
  15. Armand J Cote
    Armand J Cote
    you could machine it flat and just have keen-certs installed,
