Projects 3 deuce flathead alternator setup
Discussion in 'Traditional Hot Rods' started by atmspltr, Dec 15, 2013.
  1. atmspltr
    atmspltr
    Help!
    Running a 3 deuce intake on a flathead and am interested in using a Tuff Stuff 7781A alternator in the standard mount location (in front of carbs). Alternators are plentiful but no mounting bracket are more elusive. Anybody know where to get one?
    Text or call 757 620 2991 (Robert)
    Thanks
  2. HOTRODPRIMER
    HOTRODPRIMER
  3. Shaun1162
    Shaun1162
    Send a message to member "designs that work" on here... He makes a bracket to run a Nippon Denso mini alternator. I had one on my 8BA with three carbs- but I can't comment on fitment with any brand of intake manifold, as my intake was homemade.
    Also, if you're running the 5/8" wide truck belts he can hook you up with the right pulley for a Nippon Denso.
  4. Kiwi 4d
    Kiwi 4d
    Yes thanks HRP , I was just reading precisions build yesterday. Cool little alternator from a 4.6 mustang fits nicely in the front of triple carbs.
  5. Ron Plumlee
    Ron Plumlee
    What did you wind up doing? I have limited spacing, 59A pumps, Bubba Chev dizzy, and 4-1/2" from front of carb to rear lip of pump pulleys. Chev alt too large by one inch.
  6. Flathead Dave
    Flathead Dave
    from So. Cal.
    I pulled this off of "THE SHOP". Hope it helps.
    PROJECT FLATHEAD, PART 6
    December 14, 2010
    AddThis Sharing ****ons
    The twin water pumps have been chromed and the Tuff Stuff alternator is in it's final home.
    THE ALTERNATOR SETUP
    One of the final additions to this build concerns the alternator and the belt drive. The original engine featured a large generator that was mounted to the front of the intake manifold (the manifold features a vertical recessed channel up front that accepts a 9/16”x12 bolt). I decided to mount a modern alternator at this original location, which proved to present more of a challenge than I first thought. A popular choice is a GM alternator, but that only works with a single or dual carb setup (the issue is clearance between the alternator and the carb). Since my triple deuce setup features the Demon 98 (which is a fairly fat carb), the GM unit simply would not work. I’ll detail the parts selections and installation in this article.
    ALTERNATOR
    Because of the depth of the Demon 98 carbs (and because I’m using three of them), there simply isn’t much clearance in front of the front-mounted carb for an OE-location alternator installation. In fact, it’s way-tight, to the tune of about 1 ¾” from the manifold’s alternator mounting bracket surface to the front of the Demon carb fuel bowl. Granted, I could install an alternator offset (mounting it to the LH cylinder head), but I preferred to locate the alternator in the original generator position in terms of appearance. I initially tried a GM SI type alternator, but there was simply no way to mount this in the high central original location and achieve pulley alignment (due to the depth of the Demon front carb, the GM alternator was way too deep front-to-rear). I then tried an old style Chrysler alternator (1960-1988), which was thinner, but still placed the pulley almost an inch too far forward for belt alignment. If I was running a slimmer carb (Stromberg, etc.), Luke’s Custom Machine makes a special mounting bracket to mount the Chrysler alternator. But there simply was not enough room between pulley groove locations and the front carb.
    Left-to-right: GM, Chrysler and an OE Ford Bullit alternator. The 4.6L Bullit alternator body is the most slim, at a mere 4" in front-to-rear depth.
    Remembering that the late-model Mustang GT “Bullit” edition featured a very shallow alternator, I gave this a whirl. I borrowed a 2001 Ford Mustang Bullit alternator from my local parts store (part numbered for the 4.6L SOHC Bullit engine). This little guy features a body that’s only about 4” deep (front to rear). As a reference, the GM alternator body (including fan) is about 5 3/8” deep and the Chrysler unit is about 4 ¾” deep.
    Once I confirmed that the Bullit alternator would fit, I obtained a gorgeous triple-chrome-plated unit from Tuff Stuff (their P/N 7781A).
    Tuff Stuff’s alternators are available in chrome, polished or black powdercoat. Since it’s going to sit out front for all the world to see, I decided to go for the chrome for a dressed appearance, coordinating with the overall theme of this engine. Although originally fitted with a serpentine type pulley, Tuff Stuff swapped this out for a double V-groove pulley. NOTE: If you elect to use the same type of alternator, this is the Ford 4G. The P/N 7781 that I used originally fit 4.6L 1996-2002 DOHC and Mustang Bullit GT applications. Tuff Stuff’s P/N 8436 was original on 4.6L 2003-2004 Cobra Supercharged and Mach 1 applications. The model 7781 is available in 150 or 200 amp versions, while the 8436 is offered in 135 or 200 amp versions. Both Tuff Stuff models feature internal regulators and accept OE Ford connection (or Tuff Stuff can supply you with a 1-wire connection).
    If you’re building a flathead and plan to use triple carbs, and decide to mount an alternator in the original generator location, I highly advise choosing the Mustang GT Bullit alternator. It’s the thinnest (front to rear) unit that I found, and it looks great, especially using Tuff Stuff’s drop-dead-gorgeous chrome version (instead of using a boring OE unit, definitely go with Tuff Stuff’s P/N 7781A chrome unit).
    I then mocked the alternator in place and designed a mounting bracket ***embly that would allow me to mount the new alternator in the OE generator location. The bracket base (that mates to the intake manifold’s mounting location) consists of a 2.5”-wide x 0.500” thick slab of aluminum flat stock. I machined a 0.625”-wide vertical slot to provide a vertical adjustment range for the alternator and belts (the vertical slot accommodates the 9/16” diameter bolt (9/16x12x2) that threads into the front generator bracket wall on the intake manifold).
    I began making the alternator bracket with two pieces of aluminum bar stock.
    With the two sections welded together, I test fit the bracket and the alternator. This version was functional, but I felt that the alternator was positioned too high, so further bracket mods were needed. Excuse the weld and surface details seen here. This was during the prototype work-up.
    In order to drop the alternator to an appealing height, I relieved a pocket into the upper horizontal bar section. Since a round flat washer would not fit properly, I made a washer (starting with an ARPO crank damper bolt washer), t******* the upper half of the washer to nestle into the upper relief.
    This photo shows how the washer engages into the upper relief. This allows dropping the alternator down for belt installation, and provides washer fit when the alternator is raised slightly for belt tensioning.
    Here we see the bracket test installed prior to relieving the upper section.
    Here the alternator is mocked up with the early bracket version. In this photo, the alternator is positioned as low as the bracket allows. Once the belt is installed and the alternator is raised for belt tensioning, I felt that the alternator sat too high from an appearance standpoint.
    As you can see here, recessing the top horizontal bar allowed dropping the bracket further down, reducing the installed height of the alternator.
    With the alternator bracket modified (to lower position), the top of the alternator, with the belt tensioned, is roughly aligned with the top of the carb body. This provides a visually appealing stance. Any higher, and the alternator would be too con****uous. Call me crazy (nothing new there), but the design and the location of this alternator almost hints at providing a "blower" look to the overall scheme. I like it.
    With the alternator mocked in position, the distance from the face of the slotted aluminum bracket to the rear of the alternator’s mounting feet was measured at 0.500”. The solution was to Tig weld the vertical aluminum slotted bracket to the underside of a piece of 1”-square aluminum bar stock (with the rear of the slotted flat stock flush with the rear of the horizontal bar stock. This allows the face of the bar stock to protrude 0.500” forward of the face of the slotted plate). The bar stock was drilled and tapped with two 3/8”x16 threaded holes to attach to the alternator (spaced 4.315” on-center). The center top of the bar was also notch-relieved to clear the underside of the alternator body. This setup worked out just peachy. The alternator sits at an attractive height (even with the belt tension adjusted), placing the alternator body somewhat in-line with the Demon 98 fuel bowls, and belt line-up is near-perfect. Note: In order to create a single-belt setup to drive the alternator and both water pumps, I eliminated the RH water pump pulley and replaced it with a LH pump pulley, making both pump pulleys the same diameter and offset (remember: the original pump pulleys differed in diameter and offset). This allows me to run one belt, driven from the crank pulley’s rear groove. Belt tension adjustment is the same as with the OE setup. Loosen the 9/16”x12 bolt that secures the bracket to the intake manifold, pull upwards on the alternator and tighten the bolt. Note: In order to use my bracket and a 56” belt, the alternator’s two 3/8” mounting bolts must be backed off to allow you to slightly tilt the alternator, in order to engage the belt to the rear alternator pulley groove. You can use a longer belt (56.5” or even 57”), but that means that when the belt tension is adjusted, the alternator will sit higher. For my build, I preferred the finished height of the alternator with the 56” belt. Note: I provided details of my water pump pulley setup earlier in the water pump section of this build series.
    MY ALTERNATOR BRACKET DIMENSIONS
    TOP HORIZONTAL BAR 5.400” W X 1” HIGH X 1” DEEP
    TWO ALTERNATOR MOUNTING BOLT HOLES ON TOP BAR 3/8” x 16, spaced 4.315” apart on-center
    VERTICAL PLATE (WELDED TO TOP BAR) 2.500” W X 2.65” H X 0.500” THICK
    VERTICAL ADJUSTING SLOT MACHINED INTO VERTICAL PLATE 0.625” W X 3.00” H
    ALTERNATOR-TO-BRACKET MOUNTING BOLTS 3/8” x 16 x 2.125” stainless steel, SHCS (socket head cap screws), w/stainless washers
    BRACKET TO INTAKE MANIFOLD ADJUSTER BOLT 9/16” x 12 x 2” (grade 8, hex head) (with washer made by modifying ARP SBC crankshaft balancer bolt washer)
    ADJUSTER BOLT WASHER
    The single threaded hole (for the OE generator bracket) in the intake manifold’s front vertical mounting boss surface is size 9/16” x 12. Shank length is will vary depending on your bracket thickness. The threaded boss on the intake manifold is about 1.125” deep. In my setup, a single 9/16”x12x2” grade-8 bolt is used to secure the bracket to the front of the intake manifold. Instead of using a plain thick round flat washer at this bolt, I fabricated a custom washer (I actually started with an ARP crank bolt washer). The finished washer measures 2.00” O.D. x 0.563” I.D. x 0.280” thick. I radius-relieved the top half of the washer that would allow the washer to fit into the top of the milled pocket in the upper section of the custom bracket. In order to prevent this washer from rotating during bolt tightening, I welded a small tab onto the rear of the washer (0.250”-thick x 0.635” wide) that registers into the adjuster slot on the vertical portion of the bracket. Each Tuff Stuff alternator is built with 100% new heavy-duty components and features heavy-duty wound copper coil and spike-resistant diodes, low idle cut-in internal voltage regulator and external cooling fan. They offer either OE or 1-wire connection, black powder coat, triple-chrome plating or polished aluminum finishes, 6-groove or V-belt pulleys, and are available in 80 or 100 amp versions. In addition, their Silver Bullet models (choice of 100 or 140 amps) feature a smooth back, special fan and bullet nose and 1-wire connection. Actually, Tuff Stuff’s lineup includes not only alternators, but AC compressors, starters, water pumps, brake hydraulics and power steering pumps. Each and every item (for Chevy, Ford and Mopar applications) is not only quality engineered and offered in stunning chrome or polished finishes (some units are available in black as well), but everything is 100% made in the USA. Basically, everything they carry is show-quality and intended for the street rod/hot rod market….drop-dead gorgeous stuff that works. I’ve used their alternators, starters and power steering pumps in previous customer builds, and they never disappoint. Tuff Stuff’s motto is “Our Chrome Will Get You Home,” and they’re not lying. This is quality stuff that looks great.
    Tuff Stuff's P/N 7781A is a chrome plated direct replacement for the Ford Bullit 4.6L. Tuff Stuff offers their alternators in chrome, polished or powdercoated. The chrome version lends a nice bit of sparkle to the flathead.
    I originally went with a twin-groove pulley on the alternator (Tuff Stuff installed this for me in place of the OE type serpentine pulley).
    The off-t******lf Bullit unit originally featured the electrical connections positioned at the top of the alternator body (rear view seen here).
    Once I determined that I would use only the rear pulley groove, Tuff Stuff swapped out the double-groove pulley for this single-groove unit, and added an aluminum billet nose piece to hide the pulley nut.
    In order to eliminate the otherwise unsightly wiring connections at the top of the alternator, Tuff Stuff was able to re-clock the rear to position the connections at the lower right (rear view seen here).
    Here's a view of the Bullit alternator with the double-groove pulley and the electrical connections at top (OE position).
    This view shows the same alternator with the single-groove pulley (with nosepiece) and with the electrical connectors relocated. This really cleaned up the upper appearance. With the connectors relocated (lower, adjacent to the distributor), no wire harnesses will be visible at the top.
    The decorative pulley nosepiece provides a nice finishing touch. The cover is attached via three socket-head cap screws to the drilled/tapped face of the pulley.
    ALTERNATOR CHOICES
    As long as I spent the time to check fitment of three different alternators, I’ve listed dimensional info here to help you in deciding which is the best fit for your flathead build.
    ALTERNATOR
    CENTER OF REAR PULLEY GROOVE TO REAR OF ALT
    (approx.) GM SI type
    5 ¾”
    Early Chrysler
    5 5/16”
    Mustang Bullit
    4 3/8” (Tuff Stuff P/N 7781A)
    With my setup, I’m only using the rear groove on the alternator pulley. However, with a double-groove pulley fitted to the alternator, you then have a choice (depending on your individual setup) to drive the LH water pump using the rear groove, and the front alternator groove belt to drive the RH water pump, if you maintain an OE-type mechanical fan pulley; or to simply run one belt, providing you installed a LH pump pulley to the RH pump). Note: The belt grooves in the crank pulley are different diameters (larger diameter for the rear groove). If you keep the original water pump pulleys (smaller diameter on the RH pump) and don’t run the OE fan pulley, you’ll run into a belt ratio problem, where the two belts are running at different speeds, which will likely result in squealing or belt burnout. By running the same diameter pulley on both pumps and a single belt, I avoided this issue. I don’t care about the mechanical fan, since I ***ume that this type of engine would likely be installed in a vehicle equipped with an electric fan anyway. Besides, eliminating the mechanical fan and its ***ociated spindle/hub/bearing/bracket ***embly provides a much cleaner engine appearance. Unless you’re building a flattie for a 100-point true-to-original restoration, get rid of the OE fan ***embly.
    MY DRIVE BELT
    (to drive alternator and both water pumps) 3/8” W X 56” L For this particular setup, I used a Dayco Top Cog belt, P/N 15560. Given the crank pulley rear groove diameter, the use of LH OE water pump pulleys on both pumps, and the location of my alternator, this length was ideal. If you opt to use a different pulley setup, you’ll need to determine correct belt length for your application.
    With my fabricated alternator bracket setup, a healthy 1/2"-plus clearance was achieved between the alternator and the front carb's fuel bowl. This worked out beautifully.
    WATER PUMPS
    The boys at Tuff Stuff were kind enough to polish and chrome-plate my two new OE style Egge water pumps. I removed the black-painted pumps from the block and delivered them to Tuff Stuff’s Cleveland, Ohio facility. They removed the pulleys and impellers, polished the cast iron surfaces and triple-chrome plated the pump bodies and pulleys, then re-***embled the pumps. I was somewhat surprised to find that Tuff Stuff actually owns and operates their own plating shop (adjacent to their manufacturing plant), so they maintain total in-house control of their products from start to finish. I re-installed the water pumps, using new gaskets (treated to a fine bead of Permatex Right Stuff RTV). The 3/8”x16 stainless steel socket-head cap screws (from Totally Stainless) were installed (with medium strength thread locker) and snugged to 24 ft-lbs (the spec is 23 to 28 ft-lbs). The change to chrome plated pumps definitely makes a big improvement in the front-end appearance, providing some much-needed dazzle. The chrome contrasts nicely against the red block and the black powdercoated distributor housing.
    As shown here, in original form, the RH (p***enger side) pump pulley is offset forward to align with the front crank pulley groove. The LH (driver side) pulley is offset rearward to align with the front crank pulley groove. In my build, I was able to install a LH pulley on the RH pump and achieve belt alignment using the rear crank pulley groove and the single-groove alternator pulley.
    The original Egge water pumps are exact-to-original reproductions. However, the cast iron surfaces, although as original, bothered me, so I opted to have the pumps polished and chrome plated at Tuff Stuff.
    Here are the finished water pumps. I installed a LH pulley to the RH pump (both pumps now feature the same pulley), and Tuff Stuff chrome plated the bodies and pulleys.
  7. Missing the pics here....
  8. Kiwi 4d
    Kiwi 4d
    Thanks for that very descriptive narrative Flathead Dave. But it sure would be nice to see the pictures of this beauty.
    I couldn't find Any here either but is am computer illiterate.
  9. Shafer
    Shafer
