3 Deuce Fuel Lines...Will this work?
Discussion in 'The Hokey Ass Message Board' started by DeuceDog, Mar 18, 2006.
  1. DeuceDog
    DeuceDog
    from Breese, IL
    I made this set-up fron 2 union tees, 1 5/16 inverted flare to 3/8 hose ******( He said ******) and 5/16 in. hard lines with 3/8 fuel line to the pump. I tried to be as neat as I could, but hope this is a workable set-up. Total cost was about $15. Union Tees were $4.65 ea., hose ****** was $4 I had the hard lines, clamps, and hose.
    Any comments and suggeations would be appreciated.
    Thanks, John
  2. Dirty2
    Dirty2
    Looks good to me .
  3. cruzr
    cruzr
    well for some reason i cant enlarge your pic
    but what these old eyes can see ........looks good
  4. DeuceDog
    DeuceDog
    from Breese, IL
    Sorry for not being able to enlarge the pic. I am just getting stared with you guys and have't figured out how to do that. I had a tought time getting the image in the post.
    John
  5. seymour
    seymour
    from PNW
    That won't work. Take those 2GCs off and send them to me. ;)
  6. DeuceDog
    DeuceDog
    from Breese, IL
    Thanks...but NO! I can't wait to get it running.:D
  7. Detonator
    Detonator
    from santa cruz
    FWIW, I was going to ***emble the same kind of set-up for my three 94's (on a 322 Nailhead). I ran the idea by Jere Jobe of Vintage Carb and he said, because of the overall low pressure the 94's required, this set-up might starve the last carb on the line. I went back to three hoses out of a fuel block on the firewall. Don't know what kind of pressure your carbs need, but it's worth checking out.
  8. Nick32vic
    Nick32vic
    I wish I could enlarge the pic! haha. From what I can see it looks awesome. Someday you will have to come over and I will give you a crash course in picture posting.
    I love the color John. HAMB drags is gonna be fun!
  9. Nick32vic
    Nick32vic
    Hey, heres some pics that work. :)
    John has an awesome attention to detail. Thats one reason why this car is gonna be really cool. Now if we can just get him to put some bias-plys on there :D
  10. 7&7
    7&7
    from Colorado
    Yes it will work, no I don't see a problem with it starving the last carb. Have you ever seen a stock set? They did not use a fuel block on the firewall. Now set the body and fire that thing up!
  11. how come you did steel lines at the carbs but (ugly) black rubber hose from the tee to the fuel pump? Doesn't NHRA ask for 12" or less rubber hose in any one stretch?
  12. Muttley
    Muttley
    If you plan on keeping it that way at least put a 90 degree fitting on the end of the hard line.
  13. el Scotto
    el Scotto
    from Tracy, CA
    Yeah, why not put one more hard line between the pump and carbs, instead of the rubber hose deal?
    Very nice car BTW!!!
  14. i would stay away from that much rubber hose, just get another 3/8" hardline, bend to fit and run a flare adapter.
  15. tommy
    tommy
    you've gone this far with excellent detailing. Don't wimp out now. The first impression is that you got tired of the details and slapped the hose on there just to get it running in a hurry. You won't have to worry about starvation with 3/8 lines and a modern mech pump.
    Your engine has some very pretty detailing.
  16. andysdeuce
    andysdeuce
    The rubber line will be alright. I've run my 3 deuces like that for a couple of years now with no problems. Gives it a little more traditional look to the set-up. Every thing does'nt have to be shiney to look good. Just my 2-cents!!
  17. I agree with the others. Bend up a hard line to the fuel pump. And also plumb in one of those small in-line fuel filters Edlebrock makes.
    I ran a hard line from my stock fuel pump using AN fittings. I had to cobble up a fitting for the pump from a couple of other available fittings but it was no big deal (pictures).
    If you are going to mount your alternator on the right side of your motor it would be a good idea to have it in place when you bend up the lines.
  18. Roupe
    Roupe
    I used stainless steel lines and fittings on my 348. The advantage is the stainless will not rust and therefore does not need to be painted. It can be taken apart and put back together with out worrying about chipping the paint. It can be left satin or polished. Disadvantage, it does cost more than the steel and br***. I got all my stainless tubing and fittings from Mcmaster-Carr. www.mcmaster.com
  19. Automotive Stud
    Automotive Stud
    I'm not crazy about that long rubber fuel line. It's not so much about the look as the saftey of hard line. You need some for some flex and vibration, but my dad had his dual quad '56 chevy convert burnt up because he used rubber hose instead of hard lining it. It's a tough way to learn.
  20. Nice looking set up in a right hand drive hot rod. I'm putting my old 60 Impala 350 horse 348 back in my 59 El Camino, 4 spd and 4 11 posi, and a full set of polished Torque Thrusts, black walls, of course.
  21. Looks good.
    I'm with the guys on running hard line from pump to the first T.
    You do need some rubber for vibration induced problems, but you don't need it between pump and carb.
    Factories ran solid line pump to carb for years.
    I like seeing stuff done like this, did more than a few of them for dual quad setups back in the day.
    Makes me think a little bit about my dual quad setup, but I like the home-made aluminum fuel log so well that I'm sticking with it.
    Even so, I can still enjoy a well done one on another car.
  22. 1lowtrk
    1lowtrk
    Heres my setup almost the same.It's worked fine so far
  23. DeuceDog
    DeuceDog
    from Breese, IL
    I didn't run hard line because I was under the impression the hose looked more "old school". I guess I was wrong. I will bent a hard line if everyone thinks it is safer and looks better.
    Thanks for the comments, keep them comming.
    John
  24. DeuceDog
    DeuceDog
    from Breese, IL
    I bennt and flared the other lines. I can bent the line from the tee down to the pump...I give.:D
  25. Lose the soft hose (pressurized, a fire hazard), to finish off the *****in' look. No starvation anywhere with 3/8 line.
  26. DeuceDog
    DeuceDog
    from Breese, IL
    So your saying to run 3/8 line from the pump to the first tee? The other lines are 5/16. I do have a 3/8 line from the fuel tank to the pump.
    Thanks for the comment.
    John
  27. DeuceDog
    DeuceDog
    from Breese, IL
    Bib,
    I have a canister style fuel filter mounted on the frame ahead of the pump.
    Thanks,
    John
  28. DeuceDog
    DeuceDog
    from Breese, IL
    By the way I can BEND and I BENT the lines...Sorry.
    John
  29. hot rod wille
    hot rod wille
    i just finished my tri-power on my 29 highboy---got the hard line from Vintage Speed---I've seen posts on here on some problems with them--but I've had good luck---I needed to connect the top line to the pump---used a pressure gauge and looks good.
  30. brandonsgrandpa
    brandonsgrandpa
    I am very surprised that no one has mentioned the VERY important WOODEN clothes pin that prevents vapor lock.It should be clipped onto the line from the pump before the first tee. VERY TRAD!:p
    Brandons Grandpa,aka smart***
    On a serious note,really nice work.
    alanp561 likes this.
