3 Groove Blower Pulley's?
Discussion in 'The Hokey Ass Message Board' started by brigrat, Sep 25, 2011.
  1. brigrat
    brigrat
    from Wa.St.
    Have this question on another thread but instead of hijacking it I will post it here.
    Info needed, I have a 2" blower belt, the blower gear & crank gear are 2 1/4", idler is 2 1/8", with those width figures is there enough width to whittle a new 3 groove pulley? Nother words whats the least width it takes to make/have a 3 groove pulley? I know it would have something to do with what belts you run. Thanks <!-- / message --><!-- sig -->
  2. Paul
    Paul
    Editor
    top pulley on Cragar 3 belt drive
    lower pulley has about 1/8" seperation between the three drive belts and the fourth (water pump/generator) belt
  3. brigrat
    brigrat
    from Wa.St.
    Paul, thanks, what's the belt pt. numbers?
    Looks like you have everything in an 1 1/2"
  4. bonesy
    bonesy
  5. Paul
    Paul
    Editor
    here's the belt numbers on the set I'm running, your's of course will need to be fit to your application
    you can just see the run numbers in red, these need to be from the same run and as close to sequential as possible
    I bought this set at Williams Oil Filter on Puyallup Ave. in Tacoma
    also a shot of the lower pulley, you need some seperation between the drive and accessory pullies
  6. brigrat
    brigrat
    from Wa.St.
    All great info, thanks again Paul!
    Bonesy, interesting stuff coming out of that shop!
  7. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Yes Paul thanks for the great source of info(as per usual!!!)
    Brigrat..great speaking with you.
  8. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Bonesy.. that is awesome
  9. Halfdozen
    Halfdozen
    You might want to try an industrial power transmission place for belts, rather than an automotive supplier. They can usually supply matched sets of belts for compressors, pumps, etc. Automotive belts of the same part number are not necessarily exactly the same length, resulting in the shortest belt carrying most of the load.
  10. bigbubba
    bigbubba
    You can also buy bonded or married belts that have another strip of rubber covering all 3 belts.We used to run them as drive belts for hyd.
