3 on the tree
Discussion in 'The Hokey Ass Message Board' started by Phil 41 Chevy, Nov 18, 2012.
  1. Phil 41 Chevy
    Phil 41 Chevy
    Ihave a 64 chevy halfton pickup and looking for anyone that makes new shifter arms for it. This thing gets stuck in between gears so easy. Any help would be great, thanks Phil.
  2. dualquadpete
    dualquadpete
    You likely will have to replace all the bushing in the linkage arms & possibly the column!! When they get worn out it's a nightmare trying to "pick a gear" !! Or take the easy ****ON & put a floor shift in it!! Problem solved!!!!
  3. Phil,
    I had the same problem on my 60 Belair when I first got it. It was horrible!!! I replaced all the bushings on the shift levers and there is a adjustment on the column I tweeked a little. It is much better now. SOme of the better parts houses sell the bushings. Todd
  4. Phil 41 Chevy
    Phil 41 Chevy
    Thanks for the info, will be ordering a floor shifter tonite, but I really like the 3 on the tree .
  5. RWENUTS
    RWENUTS
    from Nanaimo BC
    What are you ordering for a floor shifter?
    Hopefully not a hurst!
  6. Phil 41 Chevy
    Phil 41 Chevy
    Cl***ic industries has one for 95.00, comes with everything.
  7. RWENUTS
    RWENUTS
    from Nanaimo BC
    Can't find it!
    You got a link or part number?
  8. Phil 41 Chevy
    Phil 41 Chevy
    cl***icparts.com part # 91-261, universal floor shifter for a truck. Hope this helps. Phil
  9. Phil 41 Chevy
    Phil 41 Chevy
    Its 99.99 insted of 95.00, sorry
  10. Don's Hot Rods
    Don's Hot Rods
    from florida
    Ok, you have my interest peaked. Why NOT a Hurst ? Probably no better shifter on the market.:confused:
    Don
  11. Rickybop
    Rickybop
    If you really like the column shifter, maybe you should try to fix it. With some new bushings, etc. you'd have 'er working nicely.
  12. RWENUTS
    RWENUTS
    from Nanaimo BC
  13. RWENUTS
    RWENUTS
    from Nanaimo BC
    You're right Don. Awesome shifter. Hurst still sells the 3 speed Master shifter. However they and no one else sells the installation kit.
    Just didn't want him wasting his hard earned money.
  14. Phil 41 Chevy
    Phil 41 Chevy
    I thought about it but the nobs are wore off the selector and the arms on the column are egged out .
  15. Don's Hot Rods
    Don's Hot Rods
    from florida
    Ok, I got it. The old Hurst SycroLoc 3 speed shifter was just fantastic. The one on my 27 is about 25 years old and I have never even had to replace a bushing in it. Never misses a shift either.
    Now, if he wants one of those Mr. Gaskets, I have the exact one you pictured, brand new one in the box I will gladly sell him for $ 20 and UPS charges. But I can't lie, they are not in the same league as the Hursts.
    Don
