???3 Speed Identity Game???
Discussion in 'The Hokey Ass Message Board' started by Termites Ate my Chevy, Jun 4, 2008.
  1. Termites Ate my Chevy
    About what year is this gm 3spd? Any other descriptions on its operation would be appreciated.
  2. Bruce Lancaster
    Bruce Lancaster
    I think '55-7 Chevy...no mount.
  3. Termites Ate my Chevy
    No mount means???
  4. oldsman71
    oldsman71
    no mount on the tail housing, used in an older truck or car with mounts on the bellhousing.
  5. panheadguy
    panheadguy
    from S.E. WI
    means no tailshaft place for the rubber mount. They had motor mounts at the front of the engine and two similar mounts at the bellhousing. Four point mounting vs the three we see after that time.
  6. Bruce Lancaster
    Bruce Lancaster
    The trans was used for a number of years, but later ones had a mount pad on the tailshaft. On '55-7 Chevies, the rear mounts were on the belllhousing and transmission just hung out in the air with no supports of its own.
  7. JohnEvans
    JohnEvans
    from Phoenix AZ
    Same lenght as a T10 -Munice- Saganaw 4 speed. 58-64 was simular but tail shaft was shorter and had a mount pad.
  8. Termites Ate my Chevy
    What kind of Horse Power can a stock one in good shape handle?
  9. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Honestly, not that much. Power pack 283s used to eat them during rigorous use. The '66 and newer Saginaw three speeds have a more rugged ge****t, and a synchro low gear to boot, and are both plentiful and cheap (sometimes even free).
  10. Bruce Lancaster
    Bruce Lancaster
    Their general weakness can be partly improved apparently by eliminating endplay in gears and adjusting endplay at 2nd/syncro area. Don't remember the tech, there is some sort of special select fit washer thereabouts. Somewhere I have a small '50's article on this...exactly same issues as early Ford box.
    Even stock cl*** cars used to eat these things...
  11. HEATHEN
    HEATHEN
    from SIDNEY, NY
    Now that you mention it, I remember an article in a late '60s HRM concerning modifying them to live longer in drag racing cl***es that required the stock transmission.
  12. art.resi
    art.resi
    Not much. I had a a warm 58 pontiac in my 55 pu and it had enough
    tourqe to break it without popping the the clutch. Rebuilt it 3 times
    befoe I got a t 10.
  13. JohnEvans
    JohnEvans
    from Phoenix AZ
    Same basic trans in 53-54 also ,killed many many of them with a 261 Six.
