3 Speed on Da Tree
Discussion in 'The Hokey Ass Message Board' started by sloppymotor, Mar 3, 2013.
  1. HEATHEN
    HEATHEN
    from SIDNEY, NY
    If your car is stock, you've got 4.11 gears. A '53-'54 rear from a stick shift car would have 3.70s, and one from a PG car would have 3.55s. Either one would help out your cruising speed.
  2. sidevalve8ba
    sidevalve8ba
    It's funny that I learned to drive on a three speed on the column almost fifty years ago but I can't upload a photo on this website to save my ****. Different technology.
  3. Don's Hot Rods
    Don's Hot Rods
    from florida
    If you want to learn to upload pictures, PM me. I am really dumb on a computer, but I have learned to do it and will walk you through it.
    Don
  4. sloppymotor
    sloppymotor
    from iowa
    It was done when I bought it...57 235, rebuilt 10 yrs ago...57 trans.. "I think he said"...the 51 driveshaft... 1950 rear end...when I got it ..It was pretty much a roller... the interior was complete.. but a barn pull...He bought a 50..4 door...and a 51...2 door....The 50 four door had the motor and trans in it...plus the rear end... of course the drive shaft was to long...so he used the 51 shaft... put all that into this 51... and some other parts as well. Then s****ped the 4 door..It started and drove off the trailer and into the garage... BUT...he was kinda a half ***..so Im very cautious at the point before I try to really cruise this thing..until I really research all the correct fluids..Ect. I don't wanna tear it up..when I could have prevented it... I ***ume he would just throw any fluid in the trans and rear end...just to get it sold... I got it for 2300.00 delivered...and have put 2500.00 in it this winter.. all labor by me...I've been through it top to bottom..new fuel tank..brake system..ect... any advice you have would be great... next step is to set valve gaps..and try to figure out the Vacuum advance / Distributor / Timing... and The carb needs a makeover. runs rich and vacuum,Im sure is off too....I think its off the 51 or 50's original motor.. It ****s but I'm tapped out on my budget.. so I cant get a new one yet.. After that we should be ready to roll...;)
  5. sloppymotor
    sloppymotor
    from iowa
    That actually raises a good point...I wonder if the previous guy .. when he did the motor, trans, rear end swap... maybe the 50 he took it from was an Auto trans... It WAS a four door..so then probably had an Auto trans...Yes / No ..?? Also..I've been told putting in a 50 rear.. would be a better gear ration.. It appears I was misinformed..?? :eek:
  6. sunbeam
    sunbeam
    A 57 trans was for open drive line and a pre 55 was closed not easy to put together.
  7. Fairlane Mike
    Fairlane Mike
    My son when he was 12, I trained him, "you need to know this", I told him.
  8. sloppymotor
    sloppymotor
    from iowa
    Hmm.. Now I'm wondering then.. what year the trans is.. It looks really good.. on the outside...Is there a way to date the trans by markings some where on it... without removing it...??
  9. sloppymotor
    sloppymotor
    from iowa
    My son is almost 13..He will be learning this summer...
  10. Rocky
    Rocky
    Classified Editor
    IDing the trans is super simple...if you can see the driveshaft with it's U-joints and watch it move, the trans/rearend is 1955 or newer. If the driveshaft is a stationary tube that is bolted to the rear axle and the back of the transmission, [actual driveshaft is inside this tube] ****** and rear axle is 54 and earlier.
    A 1955 and later trans won't work with a 54 and earlier rear axle....comepletely different because of the "torque tube" used through 1954.
  11. Mike51Merc
    Mike51Merc
    Dude, you drive Semis and you couldn't find first gear on a column shifter and you didn't even notice you were starting in second?
  12. sloppymotor
    sloppymotor
    from iowa
    Dude.. Yeah... It actually ran out of second great.. that's why I thought it was 1st..I'd think it would try to stall out starting in second..
  13. rittmeister
    rittmeister
    from texas
    My Studebaker has a 3 on the tree and overdrive. The 289 is torquey enought to pull away from a stoplight in 2nd..and the O/D works in 2nd and 3rd, so i'll drive her around town like a 2 speed powerglide..just stick it in 2nd and leave it.
    I taught my wife to drive 3 on the column last year. Teresa is in her early forties, and has driven standards since she was 16, but never on the column. Only problem we had was my 7 year old in the back claiming she was going to be sick as we went in circles around the middle school parking lot...she was just in a hurry to get the "lesson" finished so we could go to ChikFila for shakes.:D
  14. Dan Timberlake
    Dan Timberlake
  15. Mr48chev
    It's probably the first time he has ever come in contact with a column shift three speed. Us old farts grew up with them and watched who ever was driving shift through the gears from a very age and knew how to shift the gears long before we knew how to drive a car.
  16. Dan Timberlake
    Dan Timberlake
    for OP-
    http://pics.ebaystatic.com/aw/pics/viewitem/imgSoldCvi_96x96.png
    Before 1957 or so that was all any US p***enger car had.
    As a young teen walking the halls between cl***es I'd carry my books under my left arm so I could practice that H pattern. Probably made some Jenkins/Sox facial expressions as well. OMG! What if I made engine and tire squealing noises too! That kind of behavior is probably in part why Paula Lewis stood me up after she said she go to the Strawberry Alarm Clock concert with me ( still had the unused ticket in a drawer a few years ago.)
    Adding a 4 speed knob to your 3 speed floor shift conversion was a popular "upgrade" for some, kind of like those mufflers that are popular today (although I seem to sense that is starting to decline around here.)
    My high school car was a clapped out MGA, so had a 4 speed for real. The hallway practice was put to good use.
  17. Dan Timberlake
    Dan Timberlake
    Snooping around some it looks like Chevy had freewheeling in the 30s, but no OD until 1955. Surprising.
  18. When Crissie and I were dating I was driving an Austin Healey "bugeye". I rigged the steering wheel so that I could take it off when we were at the "submarine races". :p
  19. sloppymotor
    sloppymotor
    from iowa
    "Submarine Races".... I will borrow that fraise this evening..:rolleyes:
