1952-59 Ford 3 speed trans yoke
Discussion in 'Off Topic Hot Rods & Customs' started by sircampsalot2, Apr 14, 2011.
  1. sircampsalot2
    sircampsalot2
    Can anyone tell me if the yoke on the back of a 3 speed transmission w/223 is the same as a 8cyl engine w/****** yoke? thanks
  2. dragonknucks
    dragonknucks
    If I'm not mistaken, they should be the same. The only thing that's different is the bellhousing. I don't think I changed mine when I went from 223 to v8.
  3. sircampsalot2
    sircampsalot2
    Thanks dragonknucks
  4. raceron1120
    raceron1120
    You're talking about the slip yoke?
    Yup, according to Henry's part book they're all the same except cop cars. '49-'56 Part # B5A-4841-A
  5. sircampsalot2
    sircampsalot2
    Is there a Bearing inside the tail of the transmission that could be wornout instead of the yoke? When i push up and down on the drive shaft the yoke moves around inside the ******. The universal joint is tight, if there is a bearing in there how hard is it to replace? something i can do myself or would it have to go to a transmission shop? thanks
  6. sircampsalot2
    sircampsalot2
