3 speed trans
Discussion in 'The Hokey Ass Message Board' started by 66juiced, May 7, 2013.
  1. 66juiced
    66juiced
    from Austin tx
    66 f100 three on tree . Trying to figure out what tranny it has. Anyone have a idea? Thanks
  2. 66juiced
    66juiced
    from Austin tx
    Sorry it originally had a 240ci now a 300 but I used stock tranny that was in it
  3. hoop98
    hoop98
    from Texas
  4. 66juiced
    66juiced
    from Austin tx
  5. hoop98
    hoop98
    from Texas
    If it has a non-synchro first it may be a Borg-Warner...
  6. If you "Build On a Budget", this beefy trans. can be rebuilt very reasonably. I'm putting
    one in my '36 coupe for less than 25% of what the 4 speed version would cost.
  7. Fortyfordguy
    Fortyfordguy
    This is a nice and rugged all synchro 3 speed trans. Some of the early 3.03's had an odd synchro ring that is tough tofind. The later ones are generally available. Bearings, gaskets, and seals are no problem. Its a bit tough to rebuild....there isn't much space for all the parts squeezed inside. They can handle some horses!
  8. tjm73
    tjm73
    Pontiac/GM didn't have a 3 speed that could handle the power of the mighty Pontiac V8. So Pontiac went to Ford and bought the 3.03 under the name "Dearborn". They take just as much power as the legendary top loader 4 speed. Tough as nails.
    And you can convert them to top mount shifter with a Jeep T-150 3 speed cover/shifter assembly. It also happens to have the same gear ratios.
  9. '41 Chev
    '41 Chev
    I have one I'd sell (fixed yoke). $215
    I also have a '66 Ford F100 T-85 heavy-duty Overdrive trans (4 planetary OD) $550
  10. hoop98
    hoop98
    from Texas
    I had a 65 Skylark Gran Sport 400 (401) with the 3-spd toploader. I drove a 66 Ford Parts truck with the 3 spd top loader but I know they also made a BW with non-synchro 3 speed. So might want to look at Trans or build tag.
    PS My 71 Mustang had a Saginaw PS, and 72 Torinio had a Harrison Evap core and POA valve.
  11. seb fontana
    seb fontana
    from ct
    Does the T85 have the 1-3/8-10 input? I thought the one I saw at a scrap yard had the big input which I thought was strange for a late model OD trans..
  12. Relic Stew
    Relic Stew
    from Wisconsin
    Ford used the 1-3/8" input on the close ratio 3 and 4 speed transmissions behind a 390 or larger.
    The close ratio was also optional on smaller engines in some muscle cars.
