Technical 3 WW Strombergs on a Ford Edelbrock F380 3x2 intake
Discussion in 'The Hokey Ass Message Board' started by winr, May 10, 2024.
  1. winr
    winr
    from Texas
    I have an early Edelbrock F380 FE intake with the small carb flanges
    Also have 4 WW Stromberg carbs off of early Dodge truck poly 318 mills
    Any problems with 3 of the carbs working together ??
    Progressively or all 3 three tied together
    Will be going on a . 040 over 390 or 418 ( .040 over 390 with 428 crank )
    Ricky.
  2. carbking
    carbking
    If you are going for "eye candy" only, then all three together.
    If you are going for performance, I think you are going to be very disappointed.
    If you compare apples to apples and do the CFM on a 4 barrel scale, these three are about 450 TOTAL; whereas a single 4-barrel on a 390 is about 625.
    With carbs that small, the internal venturi air velocity is going to be very high. Your 390 might display its displeasure by demanding a fill-up at every filling station you meet.
    Jon
    loudbang and winr like this.
