Hot Rods 30-31 19" model a wheels on 9 inch rear need help
Discussion in 'The Hokey Ass Message Board' started by Foulkkustoms, Nov 17, 2012.
  1. Foulkkustoms
    Foulkkustoms
    from Arkansas
    I have model a wheels i want to put on my 9 inch rear end is there a way to do or not?
  2. slddnmatt
    slddnmatt
    rally america has adapters. he is wheelkid on here..
  3. hillbilly4008
    hillbilly4008
    from Rome NY
    aren't you worried about those wheels not holding up to the torque of anything more than a banger motor?
  4. 4-port Riley
    4-port Riley
    Ford F-150 pickups had the same 5 on 5 1/2 bolt pattern as the A does. 9" drums are flat (single plane) A drums are stepped so you will need to make a spacer that will make the 9" look like the A drum surface.
  5. bgaro
    bgaro
    yup, use an adapter. its got a lip for the hub, as those wheels center on the hub not the lugs.
  6. Rich Wright
    Rich Wright
    What comprises the rest of your driveline???
    These wheels are pretty spindley. They were never designed for speeds any higher than about 50/60 max. They also flex a lot both radially and laterally.
    Not knowing anything about the car your building...weight, power, etc, I can only guess its more than than a 4banger in a T or A with a modern 9" rear axle.
    You have to do what you want but please think about the consequences of exceeding the design parameters of stock 80 year old wheels.
    Things could get hairy in a hurry:eek:
    Maybe someone makes a large diameter wire with a little more integrity that would work out better for your needs.
