30-31 Ford front fender braces???
Discussion in 'The Hokey Ass Message Board' started by muffman58, Sep 28, 2005.
  1. muffman58
    muffman58
    I bolted the fenders on a 31 Ford sedan we just found [ barn find, pictures to follow soon ] Has most everything but front fender braces! My question to ya`ll is will 28-29 braces work? Or does anyone out there have a pair?? I`ll keep you in suspence a couple more days until I can get the before & after shots.
  2. The37Kid
    The37Kid
    My gress is that the shape is different, repop brackets list for around $50.00 a pair
  3. Two-Gun Bob
    Two-Gun Bob
    The front fender braces are definitely different for the different years (1928-29/1930-31). The 1928 front fenders used forged braces but then Ford switched to stamped steel ones in 1929. Early 1930 switched back to forged braces for a short while (my April 1930 Tudor has these) and then back again to stamped until the end of production (with a few minor variations in bolt holes). For the '28-'29 and '30-'31 A's, they should be able to use either version of fender brace from those years without modification. Hope this helps!
    If you need Model A parts, I recommend Bratton's Antique Auto Parts; they are honest, try to sell only the best parts available (mostly from the U.S. unless there is no other choice), and provide very good service. I'm definitely a satisfied customer! Check them out at
    www.brattons.com
  4. muffman58
    muffman58
    Thank`s for the info. I think I have a Bratton`s book around here somewhere if I can find it.
  5. Slag Kustom
    Slag Kustom
    I have been told that 28-29 fenders sit lower over the wheels then the 30-31 and that the brackets are diffrent.
  6. '29 '29 fenders are smaller.
    Look at some pictures.
