Technical 30/31 Model A Master Cylinder Options
Discussion in 'Traditional Hot Rods' started by dmdeaton, Jan 26, 2024.
  1. dmdeaton
    dmdeaton
    Haven't been on in a while. Hot rod buddy p***ed away and I sat down and lost interest. My fordor no fender banger hot rod has a battery box with the master cylinder mount built into it. It is just ok, and only a single cavity cylinder. The double will not fit, as I am running a S10 5 speed. I am doing away with the battery under the seat to give me room for a good double cylinder. Who makes a good bracket/pedal and mount ***embly? I kinda want the frame mount style unless you all tell me different. This looks good, but I would like to see some pics of one mounted.
    https://www.ebay.com/itm/1928-1931-...*embly-w-Manual-Master-Cylinder-/350514907011
  2. dmdeaton
    dmdeaton
  3. pprather
    pprather
    Does that kit have a clutch pedal for your T5?
  4. dmdeaton
    dmdeaton
    No, only the brake pedal. Thats what I am confused about. Without seeing a setup I am thinking the stock clutch pedal will not work.
  5. pprather
    pprather
    Is your current T5 clutch setup mechanical or hydraulic?
  6. tb33anda3rd
    tb33anda3rd
  7. dmdeaton
    dmdeaton
    mechanical
  8. dmdeaton
    dmdeaton
  9. A 2 B
    A 2 B
    from SW Ontario
    A better choice than the one you show would be a brake/clutch ***embly, as this will ensure proper pedal spacing and identical swing patterns. I put one in my Model A with a T5. I modified the ***embly somewhat (can't recall all the details) because of the car being channeled. I also opted for a Tilton hydraulic throw out bearing but that is all personal preference.] DSC06743.JPG
    Deutscher, mad mikey and Vic Walter like this.
  10. pprather
    pprather
  11. A 2 B
    A 2 B
    from SW Ontario
  12. Pete1
    Pete1
    from Wa.
    Wilwood makes a dual cylinder ***embly that will mount either "swing" or under the floor.
    It has a front, rear bias adjust built in also.
    mad mikey likes this.
  13. pprather
    pprather
  14. pprather
    pprather
    You'll have to visualize if the original clutch pedal will work, if you remove the original brake pedal, to be replaced by the black pedal ***embly you suggested in the first post.
    Otherwise, something like the red one shown above would need to be adapted to the Model A frame rail.
  15. dmdeaton
    dmdeaton
    It is sitting in the barn and I need to get off my **** and go look at it. This is a banger with an overhead on it. Mechanical throw out bearing. New engine was just set in last fall. I am not pulling the engine to change to hyd throw out. Currently have a single master cylinder bolted to the battery box. The style boling bros sells. Problem is that it barely fits against the S10 5 speed. I think I will buy the bracket from Ebay and modify it as needed to work with the original brake pedal. I also have a bracket to mount a single cavity Wilwod to the 5 speed ******. Really nice setup, but only single cavity. I will take some pics today and post them. Thanks guys, I thought someone would have already done this.
    The engine doesn't flex much on the mounts, but the frame does. I don't like the setup now as pedal is mounted on the engine and the master cylinder is mounted on the frame/battery box. Gotta be some flex somewhere. Again, I will snag some pics today. Thanks again
    tb33anda3rd and pprather like this.
  16. dmdeaton
    dmdeaton
    Here is what I have now. Way too tight with the battery box. It works, but I don't like it
  17. dmdeaton
    dmdeaton
    This is the trans mounted cylinder and bracket I have
  18. pprather
    pprather
    Can you modify your parts to work like this often used compe***or?
    https://www.bolingbrothers.com/model-a-master-cylinder-battery-box-***embly/
    Would that correct your concerns?
    Or start over with the BB battery box, which is similar in price to the other pedal adapters? This solution has been successfully done many times.
    Any thoughts on rebuilding the mechanical brake setup? Here is a rod that is driven regularly in San Francisco with mechanical brakes:
    https://www.jalopyjournal.com/forum/threads/building-my-first-roadster-in-san-francisco.1204990/
  19. dmdeaton
    dmdeaton
    Phil, currently running that BB battery box setup. It is fine with the single cavity master cylinder. Anything else will not fit. Too close to the 5 speed ******. I like the one I have that bolts to the S10 ******, and may modify it to adapt a double master cylinder. I also want to add the proper valves to a double and get this right. It is an old banger hot rod, but I want to get the stopping right. Its all another reason to get the battery box out of the way also.
    pprather likes this.
  20. pprather
    pprather
    I think I finally understand what your desire, with both the pedals and the master cylinder mounted to the engine/transmission.
    On my A, the battery was in a homemade angle iron frame on the p***enger side.
    Another thought is to provide some stress relief for the frame mounted hard brake lines?
  21. Phil P
    Phil P
    IMG_1116.JPG IMG_1115.JPG I moved the battery box to the p***enger side and used the Boling brothers model a brake and clutch pedal ***embly with the mustang master cylinder. I fabricated a mechanical linkage to the clutch fork.
    Phil
  22. dmdeaton
    dmdeaton
    thanks Phil, good pics. And helps a lot. I hate to chop more out of the crossmember, but looks like it is needed. I ordered parts and when the weather breaks a little I will get planning.
    Tow Truck Tom likes this.
  23. leadsled
    leadsled
    I'm dealing with a similar situation on a Y-block/T-5 roadster build. My crossmember is 7" from where I want my pedal bracket. If I go forward the bellhousing takes up a bunch of real estate.
    I haven't done it yet but I am think about moving the master cylinder behind the cross member and building an extension rod.
    Tow Truck Tom and X-cpe like this.
  24. X-cpe
    X-cpe
    That's what I did with mine. Car is channeled the height of the frame and I didn't want the M/C hanging below frame, but I needed to keep the front of the floor as low as possible for leg room. Moved the M/C back to right in front of the seat and cut away what I didn't need of the old M/C and pedal mount. Bought a piece of DOM and a male Heim joint.
    Tow Truck Tom and leadsled like this.
  25. leadsled
    leadsled
    Looks like you caught it before you built your cross member. Looks strong enough too me.
