Projects 30-31 RPU CAB
Discussion in 'Traditional Hot Rods' started by coonpiss, Apr 1, 2015.
  1. coonpiss
    coonpiss
    from NW Indiana
    Asking for some help here with my RPU cab. Mocking it up for the first time and I'm wondering what the cab back dimensions should be. I cut down a roadster sub frame and everything is looking alright so far but I'm at a loss on the cab back. Am I missing something or just looking at it wrong. First time doing this. Thanks, Pat
  2. slv63
    slv63
    I would say either get or mock up the doors before you get too far. The doors will tell you where the back needs to be
  3. mike bowling
    mike bowling
    Agreed- Doors are the key- roadster doors are a couple of inches shorter than coupe doors. The sub-frame will definitely require some cut-and-weld fitting. Line up the sheetmetal, and it should tell you what you've got to do. Keep in mind, the "A" doors are an "over-lap" fit ( around 1/4 "), not flush on the "B" piller ( or cab-back). If in doubt, find one to look at . Slow and steady wins the race! Good luck with it.
    slv63 likes this.
  4. mike bowling
    mike bowling
  5. coonpiss
    coonpiss
    from NW Indiana
    Still on the hunt for a set of doors and found out my cab back is 54" instead of the 52" it's supposed to be. Still looking for pics and other details on the cab back. I think I may have to wait until iola for a set of doors.
  6. Roger53
    Roger53
    Yes you really do need your doors or you'll be cutting up doors to make fit. Good luck! Roger
  7. coonpiss
    coonpiss
    from NW Indiana
    Finally found me a set of doors!! Now I can start bugging everyone about other stuff.
  8. I have a '31 RDPU but I don't know what you are looking for? Once you put the roadster doors on everything should go together.
    Charlie Stephens
