30-40's Zip Tie Equivalent
Discussion in 'The Hokey Ass Message Board' started by brawler500, Jun 12, 2007.
  1. brawler500
    brawler500
    from Roxbury NJ
    Was there a zip tie equivalent for wiring harnesses that was used in the 30-40's or was the common practice to use friction tape or a cloth loom?
    David
  2. Friction tape I think
  3. All I ever saw was a white waxed string, tied tightly and snipped off clean.....Really looked neat.
  4. Nightshade
    Nightshade
    I seem to remember a thread where someone posted the string and the method used which was taken from aircraft wiring setups. It was an excellent article and thread on the subject.
  5. terrarodder
    terrarodder
    from EASTERN PA
    We used friction tape too.
  6. Kevin Lee
    Kevin Lee
    Super Moderator
    Believe it's restoration supply that carries aluminum ties. Genius little things - much like a zip tie - that have to look cool as hell installed.
  7. alchemy
    alchemy
  8. Bruce Lancaster
    Bruce Lancaster
    Also look into Adel clips, now sold under generic terms, strips of rubber-insulated aluminum made to fasten aircraft wiring to structure. This was a common WWII surplus item used on many rods, sort of a high tech upgrade to Ford issue wire to frame clips.
    The aluminum tie strips are neat...I have never found any info on how old they really are. I have seen them in 1950's GM accessory packages to clip wire bundles from the accessory to existing wires, but don't know if they were available in 1930 or 1940...if they go back, I bet they turn out to be another aircraft bit.
  9. Bruce Lancaster
    Bruce Lancaster
  10. Gman0046
    Gman0046
    I used to be an A&P Mechanic for a major airline. What a great source of clamps, equipment and supplies for the auto enthusiast.
  11. theHIGHLANDER
    theHIGHLANDER
    I've done lots of restoration to 30s American cars. I've seen the string method many times but the best looking was a small strip of plated tin that just got bent around the wire to keep it together. I would subs***ute stainless that was scuffed with a red scotchbrite pad and cut into 1/4" wide strips about 4-6" long. It would wrap around a Packard under-dash harness twice and not let go. And it looks authentic
  12. Nightshade
    Nightshade
