Projects '30 A Tudor Sedan build
Discussion in 'The Hokey Ass Message Board' started by Greenblade, Mar 23, 2023.
  1. Tim
    Tim
    from KCMO
    They all look the same on the outside. The only visual thing I can think of other than the number on the block which you could print or save a cheat sheet for is the earlier motors have a hole in the back of the block behind the intake manifold from at least 67 and older. It’s for the road draft tube or pcv .
  2. lumpy 63
    lumpy 63
    Also make sure it has a two piece rear main seal, the later ones 88? And newer are one piece.
    SS327 likes this.
  3. lumpy 63
    lumpy 63
    Look for the " how to rebuild your small block Chevy" book by David Vizard. Its the book I used when I was a kid , its loaded with great info like casting #s etc.
    SS327 and guthriesmith like this.
  4. Greenblade
    Greenblade
    I'll be on the lookout for an early 350 block then. If I find one, I'll probably still take pictures and ask the hamb, better safe than sorry
    lumpy 63 likes this.
  5. rusty valley
    rusty valley
    That drivers side fender looks like a proper repair, whatcha complainin about ? I see an old /2 beemer hiding in the shop, I'm a Beemer guy too
  6. Greenblade
    Greenblade
    I actually was thinking of keeping the fenders mostly as they are, a few cracks and sharp bits will need some work. Someone clearly cared enough to fix it and drive it like that, so as the Squirrel Nut Zippers said, "if it's good enough for granddad, it's good enough for me" 20230326_113530.jpg
    That BMW is my dad's @rusty rocket . I always thought it was a cool bike. I've never seen the thing run, something was wrong with it but not sure what. 20210903_125418.jpg 20210903_125425.jpg 20210903_125432.jpg
  7. rusty valley
    rusty valley
    Very nice original bike !
    Greenblade likes this.
  8. rusty rocket
    rusty rocket
    Want to buy it. 68 r60. Quit riding it because it had a tick on the right side almost positive it was a sticky lifter.
  9. wheeldog57
    wheeldog57
    @Greenblade model As have the VIN stamped on the top of driver's side frame rail a couple or 3 times. I've seen guys use an engine hoist and carefully placed straps to pull off a body solo. Keep us in the loop bud
  10. rusty valley
    rusty valley
    @rusty rocket , currently my life is in this state...don't need any more, don't want any more, can't afford any more, have no more room to store any more...etc. Nice bike tho, /2 beemers are quite valuable these days, you have a good investment there. I've had two, a 56, and a 67, wish I still had them. Happy motoring.
  11. Greenblade
    Greenblade
    ok so I plan on removing the fenders and unbolting the body around noon today. I've never done anything like this before so if any of yall got advice on this process, that'd be great. I'll be bringing, wrenches, torch, some sort of lubricant. and a weed wacker.
    Tim likes this.
  12. Kevin Ardinger
    Kevin Ardinger
    My advice would be to add a 12 pack to your list of tools.
  13. As far as fixing the fenders, just remember that it probably wasn't driven over 50 mph that way. A lot of wind resistance at higher speeds might cause havoc with that torn sheet metal. I'd at least tack some welds to hold it together.
    Love what you're doing, tho. I've got a 29 that I should start putting together so I'm watching!
  14. wheeldog57
    wheeldog57
    It's 9:30, are you done yet? With any luck you'll get the body bolts out without too much hassle. Good luck
  15. manyolcars
    manyolcars
    86 and newer are one piece rear seal
  16. Greenblade
    Greenblade
    My plans to do this solo are a no go. This is as far as I could get before every bolt was stuck. Need help from people who know their stuff. I want to pull it out and work on some flat hard ground but the front end is just sitting in loose 20230416_123405.jpg
    SS327 likes this.
  17. Greenblade
    Greenblade
    Found a few body bolts I could get loose. And cleared out loads of moist soil from the back seat area. Surprised how rot free most of it was. Despite not getting done what i planned, i had fun working on something again. 20230416_144753.jpg 20230416_144802.jpg 20230416_151640.jpg
    OFT, SS327, Stock Racer and 3 others like this.
  18. Greenblade
    Greenblade
    Bought a hood. Flames were a bonus!:cool: 20230417_191501.jpg 20230417_192253.jpg 20230417_192257.jpg 20230417_192302.jpg
  19. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    I like fenderless everything. Here is the tudor I did a few years ago...
    https://www.jalopyjournal.com/forum/threads/1931-ford-tudor-vintage-hotrod-rebuild.1202123/
    The SBC is the pumpkin spice latte of motor swaps in my eyes. Take a look at my banger coupe also if you want to go down the banger rabbit hole. If you can source a good running banger for a couple hundred bucks, throw a downdraft on it and get out there on the roads alot faster. You can always swap motors later if you want. Plus you can make the old gal run and drive very orig to know where you are coming from and where you are going. Just trying to get you an option since you are trying to get through school etc. Cheap fun can be had in these cars with not much work...
    OFT likes this.
  20. Greenblade
    Greenblade
    This morning I pulled the passenger door off to work on that. It needs some sandblasting and patchwork on the bottom, I intend to do this myself. While I was doing that I took a closer look at the fenders and did some thinking, I should probably get better fenders. I think I can make the drivers side fenders work but the passenger side ones look to be too far gone. 20230430_102309.jpg 20230430_102315.jpg 20230430_102319.jpg 20230430_102324.jpg 20230430_102328.jpg 20230430_102333.jpg 20230430_102352.jpg 20230430_102400.jpg 20230430_102408.jpg
  21. I love the "Farmer repair" on the front fender , made to last a while. Model "A"'s want to be chopped 5 inches.
  22. Greenblade
    Greenblade
    Gonna forget about engine stuff for now (but if you do have old weiand stuff, send me a message)
    My main focus will be fixing up the passenger door.
    This door has none of the innards, it's just a shell, so I'm wondering if there's a place that makes reproduction door parts or if I have to find used? 20230430_102408.jpg
  23. Kevin Ardinger
    Kevin Ardinger
    Aren’t there small journal 327s? Like the early ones?
    OFT likes this.
  24. Tim
    Tim
    from KCMO
    Yeah I think so but it’s less common to come across I believe
    OFT and Kevin Ardinger like this.
  25. lostone
    lostone
    from kansas
    You can get lower outer skin patch panels and the lower inner structure patch panels for the doors.
    I suggest you repair the doors from what I can see. Used doors aren't cheap and besides chances are any doors you find for sale will need body work anyway if not patch panels too.
    Just Gary and Greenblade like this.
  26. Greenblade
    Greenblade
    I plan on getting a patch and doing the work myself, this door is already second hand, my Papa said he bought it on ebay years ago.
    I'm looking for all the mechanical stuff for the inside, window crank, door lock handle, etc.
  27. lostone
    lostone
    from kansas
    Alot of the mechanicals inside the door are available as repo products now. Latches, window mech, etc.
    I'm looking to update mine, people say the late 90's jeep cherokee window mechs good in these doors but the down side is the manual window tracks aren't reproduced.
  28. AHotRod
    AHotRod
    I thought you could use some pictures of Hot Rod Sedans to keep you awake all night ....
  29. Greenblade
    Greenblade
    Still looking for a title before I get to really working on this thing. Until then I'm doing things like this to keep me motivated 20230529_133903.jpg 20230529_133915.jpg (just soapstone for now)
    Just Gary and '28phonebooth like this.
