Projects 30 Coupe floor measurements
Discussion in 'Traditional Hot Rods' started by SMH, Jan 4, 2021.
  1. SMH
    SMH
    I got the floor pans for my 30 Ford Coupe and they are way off. Can someone give me the measurements of the floor pieces. I need to see if my car is wrong or modified someway or if I got the wrong floors.
    [​IMG][​IMG]
  2. -Brent-
    -Brent-
    Looks like it has been modified to fit 32 rails.
    I don't know about those pieces that are too narrow, they don't look like stock style floor pieces.
    mad mikey likes this.
  3. SMH
    SMH
    Flathead Dave likes this.
  4. -Brent-
    -Brent-
    If nobody chimes in, I'll see what my measurements look like.
  5. SMH
    SMH
  6. -Brent-
    -Brent-
    My back portion: 20210104_192706.jpg 20210104_192807.jpg
    Sorry, my bulkhead doesn't allow more measurements.
    Front/seat panel:
    mad mikey and Flathead Dave like this.
  7. SMH
    SMH
    Thanks. That helps. Yours is definitely different than mine it looks like.
  8. SMH
    SMH
    I guess mine was modified in some way to be wider. And they modified the back for the 32 rails like you said. Oh well some money wasted but I will modify them to work. I just hope I don’t run into anything crazy on the firewall.
    Thanks again for the help.
  9. -Brent-
    -Brent-
    When I was looking for dimensions, I found that they varied, too. I'm not all that far off from you.
    Still, we just made our own floors.
    Are you going to run a 32 frame or an A?
  10. Dino 64
    Dino 64
    from Virginia
    Across in front of the seat, the rear has been modified, this part is stock tho 5C86C8DE-81E5-40BE-88AB-58CEEB0276C1.jpeg F4C799FF-655C-44A0-AF45-F810564640E7.jpeg
    mad mikey and -Brent- like this.
  11. SMH
    SMH
    Yes 32 Frame
  12. I made my floors as well, I wonder if those could be for 28-29?
  13. -Brent-
    -Brent-
    It certainly doesn't appear that your sub rails are modified for width. The rear section has to be removed/modified removed to fit the frame. What's your concern with the firewall?
  14. SMH
    SMH
    No concern yet I haven't tried it.
  15. chev34ute
    chev34ute
    I am no expert but your floor pans are not stock style ones. These are the ones I made up in 2019.
    AD568FCB-A67E-47F2-9B45-E2EC8245C394.jpeg 4B0D5F53-C653-43EF-AF3A-EDF2D8426CB7.jpeg
