30 ford 5" chop
Discussion in 'The Hokey Ass Message Board' started by Ron s, Oct 16, 2007.
  1. Big Dirty
    Big Dirty
    The silver coupe above almost looks exactly like my car before I sprayed it, what a trip.
    Dirty
  2. A 31 MO FO
    A 31 MO FO
    from D/FW
  3. Ralph Moore
    Ralph Moore
    Nice chops! Makes me think of buying a Real Steel 30-31 5w and putting it on my 32 ch***is, instead of a gl*** 32 5W. On those pics, how hard is it to get the 30-31 body to match the 32 frame? Also I noticed the firewalls didn't bulge out like a stock 30-31, did you replace them, or just set them back a little?
    Ron s likes this.
  4. Ron s
    Ron s
    Sorry guys off topic. I wish to share some photo's however I can't figure out how to attach a thumbnail photo?
  5. Lucky77
    Lucky77
    If things get too cramped with a chop and chanel you can also sink your floor pans. You'll be seated below the top of your frame, it gives you a little more head room.
  6. Ron s
    Ron s
    I think I have it...4" chop works well only because my tape roll is 2" wide....Picture attached of my 57 Mercury "Rat rod"
  7. EL BOZITO
    EL BOZITO
    from EAST BAY
    if you think dirtys coupe is nice, you should see his hair in person on a "good hair day". puts that car to shame...
  8. A 31 MO FO
    A 31 MO FO
    from D/FW
    M R purdy rat rod.:confused:
  9. Lucky77
    Lucky77
    Might want to move that tape up a little bit. Cutting the straightest area of the pillars makes it easier to fit the two halves back together. If one part is straight and one's curved they don't fit back together very well. Your back side window might end up looking goofy if you cut it there too.
    Ron s likes this.
  10. terrarodder
    terrarodder
    from EASTERN PA
    If you plan to drive it, check to see if you need a certain windowshield height. In PA. you need 7" vert. height at the lowest point, not length of gl***. I'm not a big fan of chopping the **** out of it and having it look out of preprotion with the rest of the body.
  11. kennedy
    kennedy
    from TN
    I went 4"...
    Ron s likes this.
  12. Big Dirty
    Big Dirty
    Well it ain't broken, and when the hood is done we'll see if it's pointing up.
    If it is, would you consider it "Sinister"???
    Ron s likes this.
  13. Ron s
    Ron s
    Lucky77...Might want to move that tape up a little bit. Cutting the straightest area of the pillars makes it easier to fit the two halves back together..........Good catch. Thank you. I have since moved my cut lines up two inches which appears to be the straightest spot. Thanks again...
  14. j ripper
    j ripper
    from napa ca.
    i can only give 3 "
  15. Pinstriper40
    Pinstriper40
    I chopped my '29 coupe 3" last weekend. Being a small giant at 6'5" I haven't decided to channel it yet, as leg room is rare in an A. It should look good when you're done!
  16. j ripper
    j ripper
    from napa ca.
    two more
    Ron s likes this.
  17. Ron s
    Ron s
    j ripper.....Thanks for the photo's. Yours is exactly how I invision mine turning out. How did you make your cut? Saws-all or cutt-off-disk?, also what did you use for a brake conversion? Thanks again....
  18. j ripper
    j ripper
    from napa ca.
    i actually did the cutting with a jig saw and some nice long metal blades. personally i would say it works out pretty darn good. as for brakes i used 40 ford with 39 pedal ***embly. spindles and rear end 40 also.
  19. j ripper
    j ripper
    from napa ca.
    forgot to mention. the 3 " cut was centered in the 1/4 window and followed throughout the rest.
  20. fur biscuit
    fur biscuit
    don't be so modest, that chop is award winning! you silly kid.
  21. Take good care of my baby,that was mine for nay on 23 years,I think I.m going to shed a tear:eek:
  22. touchdowntodd
    touchdowntodd
    mine is chopped 5" with a 4" channel, im fat and 6'1" tall
  23. j ripper
    j ripper
    from napa ca.
    ok, it turned out pretty good... for a wood worker...
  24. F'n-100
    F'n-100
    That's perfection. I love it.
    Later, F'n-100
  25. 36Brua
    36Brua
    quote=j ripper;2303161]forgot to mention. the 3 " cut was centered in the 1/4 window and followed throughout the rest.[/quote]
    I have to agree w/ fur biscuit
    I've looked j ripper's car at 2 shows recently. 1st time... that is a nice car . 2nd time at hot rod revolution..... it is A really sweet ride. real AV8 coupe. But hey this is N. California....
  26. Ron s
    Ron s
    Good morning ....4" chop complete, roof going back on...all is well..
  27. j ripper
    j ripper
    from napa ca.
    lookin good ron.... keep us posted on the progress.
  28. Ron s
    Ron s
    Some more welding and grinding to do...Stopped at 4", thinking I may want to channel it still. Easy chop...Today..Sunny day, work on the car for a couple hours, go White tail hunting later this afternoon.....
  29. Dreddybear
    Dreddybear
    Lookin good man. Channeled will be sweet.
    Ron s likes this.
  30. Noland
    Noland
    I chopped my coupe 4"
    channelled it 8"
    Im 6'
    Lets say Im glad I didnt chop It 5"
    Its seriously that close
