Hi folks, I'm new to the forum and looking forward to learning from you folks. The body of my 30 is in fair to good condition some patch work at bottom of door and quarter. The top has been chopped 3" and I currently plan to channel 4" over a model A frame. I need a deck lid and plan on purchasing the deck skin and fabricating my own inner panel (cost issue) has anyone gone through the process of fabricating an inner deck lid panel? I would also like your input on good source for a rolling Model A ch***is? Thanks Ron
Try the cl***ifieds here or at http://www.fordbarn.com/ for a rolling ch***is. Good luck and welcome from Michigan.
Hi folks anyone know of a good book with illustrations showing how the body is ***embled. For example my 30 coupe has a angle iron brace which runs across the front roof opening from drivers side to p***angers side is this OEM? Posted using the Full Custom H.A.M.B. App!
ya it is....OEM. I am finishing my 30 coupe in the next few weeks. I can snap a picture for you and show you mine. ch***is are all over. hard part i found with my 30 was small things. door hinges and stuff like that. 30/31 are different than any other year.
welcome & post some photos when you can ! It will be easier for us to see what your in need of and if you really need a replacement, sometimes its a simple fix, not everything you need is reproduced you will have to do some fab work
I would like to see your photo's My email is ronald54@cox.net Posted using the Full Custom H.A.M.B. App!
Thanks I will post pictures ***uming I can learn how. Thanks again for info. Posted using the Full Custom H.A.M.B. App!
Thanks for the welcome can you tell me how to post pictures of my project? This is my first project and need lots of help. My body (30 5 window coupe) is in fair shape how ever I really need ch***is suggestions currently considering a Model A roller. The coupe has been chopped 3" and I plan to channel 4" over the ch***is. Any help would be welcome. Posted using the Full Custom H.A.M.B. App!
Welcome Ron. A bone coupes are the coolest. Chopped and channeled even cooler. You are posting on the "introduction" section of the forum (where you tell us about yourself), so your questions are being seen by a limited few. You should post about your build and the questions you have on the main forum. Look here: http://www.jalopyjournal.com/forum/faq.php?s=&do=search&q=+Attachment***atch=all&***lesonly=0 for how to attach pics.
Welcome from Carroll County, Maryland. I may have a lead for a complete "A" ch***is....let me check on it first. Murph
Did you happen to find anything new on the model A ch***is. Thanks Ron Posted using the Full Custom H.A.M.B. App!
