Does anyone know or have the measurements for a 30 model a rear roll down back window? Need to get a gl*** cut? Thanks Stixs
You may want to make a pattern of the rear gl*** from either heavy cardstock or posterboard. When you are satisfied with the pattern, transfer it to a template made from a piece of 1/4" plywood. Make the final adjustments and when you are happy with the fit, drop it off at your local gl*** cutter... <LEGEND>Attached Thumbnails</LEGEND>
