Projects 30 model a
Discussion in 'Traditional Hot Rods' started by Carl Gibbs, Jan 10, 2021.
  1. sloppy jalopies
    sloppy jalopies
    on closer inspection those welds do look like like a row of dimes !
  2. Carl Gibbs
    Carl Gibbs
    Thanks . I'm going to get it finished clean it up and paint. Then hopefully onto a drop axle.
  3. roddering
    roddering
    from Arizona
    Keep at it, looking great!
  4. 42˚18'N 83˚09'W
    42˚18'N 83˚09'W
    I think he's got the idea...
  5. marc billen
    marc billen
    from lakeside
    looking good, keep posting pictures
  6. Never2low
    Never2low
    With permission from the OP, I'm posting some pics of my engine and trans, he's interested in.
    Both of us are fairly green when it comes to Flatheads, so I thought it best to let some more experienced eyes render a verdict.
    I don't want to unintentionally misrepresent anything, and it gives him some peace of mind.
    Pretty sure the engine is a '42, 221ci.
    3.0625 bore, 3.75 stroke
    Spins freely by hand.
    Only pulled one head, but no visible cracks, and the bores look good, other than carbon build up.
    Never got around to pulling the other head, or the pan, to check for cracks.
  7. Never2low
    Never2low
    '39-'48 3 speed. Some light surface rust, but no pitting.
    Gear teeth look good, not sure how to check for shaft slop.
  8. Carl Gibbs
    Carl Gibbs
  9. Carl Gibbs
    Carl Gibbs
  10. Carl Gibbs
    Carl Gibbs
    Ok so still parts collecting. Got a flathead and 39 trans from a guy here on the hamb. Also recently ordered a drop axle setup with spring. It is on back order but should be on its way soon.
  11. Carl Gibbs
    Carl Gibbs
    Built a little stand for the ****** so it didn't roll around on me :D
    winduptoy and loudbang like this.
  12. rusty valley
    rusty valley
    Lookin good ! Use a real ford axle, way mo better and available now
    Just Gary and loudbang like this.
  13. fordgezzer
    fordgezzer
    from texas
    Nice start!
  14. WIDE BOX BENNY
    WIDE BOX BENNY
    NICE!
  15. Drysump
    Drysump
    Nice! You’re making quick progress seems like. I think we’re on the same track, just I’m 6 months behind you. Pretty small pile of parts so far, but I’m surprised at how many of Henry’s original parts are still out there almost 100 years later. The hunt is half the fun! Hope the flathead works out well for you.
  16. Carl Gibbs
    Carl Gibbs
    Thanks. Alot of parts out there and alot of learning and figuring out in the process.
  17. 65stang85
    65stang85
    from michigan
    Nice, happy to see the flathead is going in it.
  18. Carl Gibbs
    Carl Gibbs
    Yup me too. I actually gave a nice 302 that was the original plan but could not get the flathead idea out if my head. Especially the more I get into this and look at other cars.
  19. pitman
    pitman
    ♥️ always knows!
  20. Carl Gibbs
    Carl Gibbs
  21. Carl Gibbs
    Carl Gibbs
    Finished boxing a few weeks ago. Just now throwing pics up.i didn't go all the way to front crossmember. Cuz I know motor mounts are going to sit in there.
    oliver westlund likes this.
  22. Carl Gibbs
    Carl Gibbs
  23. Carl Gibbs
    Carl Gibbs
    Bought a rear spring. Gonna start cleaning the rear-end up and figure out a rear brake set up.
  24. FritzJr
    FritzJr
    You will want to pressure test that flathead engine before you go to far with it. You can do a simple pressure test with the heads on. You can then confirm whether or not it has internal leaks. If leaks are apparent, then you have to do more to find the source. Some flathead cracks can be fixed. Others not so much.
  25. Carl Gibbs
    Carl Gibbs
    Yup thats what I've been reading. The plan is to get tires on the ground line the engine and ****** in. Get the motor mounts installed. Then pulling everything back apart and going from there.
  26. sloppy jalopies
    sloppy jalopies
    did you run a string from front to back to check for sag ? mostly near the motor mount...
  27. Carl Gibbs
    Carl Gibbs
    No I didn't. Thats a good idea though. I will.
  28. Carl Gibbs
    Carl Gibbs
  29. Carl Gibbs
    Carl Gibbs
    Spring installed. Left to 2 leafs out for now.
  30. Carl Gibbs
    Carl Gibbs
    Ok guys. Change of plans. When I got into this car I was going with a model a frame. Going to a few car shows throughout the summer ideas change. I have been really drawn to these cars with the 32 bones underneath. Looking into how much a true 32 frame would run I had a buddy of mine build me one. Turned out great and think it better fits what I have planned. Still plan on running the flathead and 39 3 speed that I got . but did install 9 inch rear. I have a 39 rear buggy spring to install yet. I think this set up is more my style.
