Technical 30 model have a VIN?
Discussion in 'The Hokey Ass Message Board' started by JD Miller, Mar 6, 2026.
  1. JD Miller
    JD Miller
    Does a original 30 model a coupe vin # ? Or would it be a newer added DMV sticker or something
    Found one for sale . Seller says he has a ***le "for a 30 model" cars in washington...
  2. rusty valley
    rusty valley
    Originally, it had a serial number on the engine block, and the drivers side frame rail under the cowl, and they matched.
  3. JD Miller
    JD Miller
    How do you view the frame stamp ? In side through the floor board?
  4. rusty valley
    rusty valley
    Not one of Fords better idea's, you have to lift the body, and then the running board aprons have been rubbing on the numbers for all of time so they can be very hard to see.
  5. alchemy
    alchemy
    Top of left frame rail, right in front of cowl. That is the number that should match the ***le. Be aware that not many Model A’s have their original engine.
    Deutscher, dana barlow and Just Gary like this.
  6. Dave Mc
    Dave Mc
    To see the VIN the body has to be lifted or off the frame, when DMV tries to verify the VIN , after the car is finished and they feel ***ured that it is legit, that's when they add those number tags on the A Pillar.
    Deutscher and rusty valley like this.
  7. JD Miller
    JD Miller
    Right on... Exactly what I was wondering
    Deutscher likes this.
  8. 1946caddy
    1946caddy
    from washington
    Deutscher, deadbeat and clem like this.
  9. Almostdone
    Almostdone
    From a ‘31…. Zoom in on the chalked area.
    John
    warbird1, Deutscher and rusty valley like this.
  10. RodStRace
    RodStRace
    Selling a car and 'a ***le for a 30 model'? Just the ***le?
    Search for "VIN" here in general discussion. This has been argued about for decades.
    Also search for your (Idaho) state's laws and rules on this sort of thing.
    https://itd.idaho.gov/dmv/
  11. 31Apickup
    31Apickup
    All Model A engines were built at the Rouge plant and the Serial number was stamped consecutively there. Then the engines were sent out to the various ***embly plants where that same number was stamped on the frame (I’m sure some were missed). It is a serial number not a VIN although it was used for registration.
    warbird1 and Deutscher like this.
  12. Only if you live it a state that had ***les in 1930 and that issue ***les for cars that old.:rolleyes:
  13. alchemy
    alchemy
    And if your aunt had balls she’d be your uncle.
  14. proartguy
    proartguy
    from Sparks, NV
    This is correct.
    Many states later used the engine number for ***le purposes and that can lead to problems if someone later finds out the engine had been replaced and doesn’t match the frame number. Just speaking from experience. Most en***ies use the frame number now.
  15. 5window
    5window
    Why not start the other way around? Find out what Your State requires for a ***le. Then find out what information the seller has on his "***le". Maybe you will get lucky. My '31 came with PA ***le converted from an Ohio ***le ( don't know how) which was the vacated by the PA DMV who then issued me a new Pennsylvania street rod VIN plate which is now attached to my firewall. The DMV can be a strange world. Also contact your elected state representative. One of their jobs is to help cons***uents get through the h***les of state bureaucracy. They should have plenty of time. No one's elected officials seem to be doing much these days. :)
