1952-59 Ford 302 coolant hose question
Discussion in 'Off Topic Hot Rods & Customs' started by demonspeed, Nov 18, 2012.
  1. demonspeed
    demonspeed
    Hey guys I want to run coolant hoses from my water pump to my intake manifold and from my water pump to the thermostat outlet on my 302. Im not interested in running any to the heater core at the moment. I tried using some random bulk heater hose but the bends seem to be too tight, and the hoses kink. Does anyone make preformed hoses for this? If not, what have you guys used to do this?
  2. CptKaos
    CptKaos
  3. old lady's mad
    old lady's mad
    dayso and gates both make a 90 degree heater hose in various lengths you could buy a short one and use, the one from the t-stat housing to the pump is called a byp*** hose directly made for the engine.
  4. demonspeed
    demonspeed
    Larry those look more like block off caps. I'm looking for hoses that will allow the coolant to flow through the engine, without having to run coolant hoses to the heater core
  5. Nite Owl
    Nite Owl
    Water will still circulate if you use the block-offs on the intake and water pump.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
