1952-59 Ford 302 head hits firewall
Discussion in 'Off Topic Hot Rods & Customs' started by NC Customline, Mar 5, 2024.
  1. NC Customline
    NC Customline
    Guys
    I’m having trouble getting my 302 back enough to make motor mount lineup. The drivers side head hits the firewall with about 1” to go . I tried switching mounts around but that made it worse. Any suggestions?
  2. craigtone
    craigtone
    What mounts? I have the Butch's mounts and have no issues at all. There are 2 versions also and you have to measure to make sure you get the right ones since I know the 1953 had 2 different frames.
  3. NC Customline
    NC Customline
    Craig
    I’m using the stock mounts from the mustang gt that I got the motor out of . I do plan on switching to new mounts for final install but right now I was just doing a fit check . I didn’t know if by chance the AFR heads are a little bigger then stock , that doesn’t seem that would come into play . The car is a 55 so I don’t know if that makes a difference.
  4. craigtone
    craigtone
  5. nosford
    nosford
    The 302 is the opposite of the Y block on which head is further back so yes, the firewall is staggered to the wrong side. I have a 302 in my 55 and posted how I did it several times using 66 mustang 289 mounts and a couple adapters. The mounts are cheap and fit several different 60's and 70's ford cars. Most recently posted in 56 mercury frame notch with pictures a few posts down from this one. Mark
    Adriatic Machine likes this.
  6. NC Customline
    NC Customline
  7. JeffB2
    JeffB2
    from Phoenix,AZ
    These are the mounts I advised him to use. https://www.jalopyjournal.com/forum/media/albums/289-302-351w-swap-mounts.41498/ Butch's was bought out by Shoebox Central this is the kit Butch's had https://shoebox-central.com/2507cp-...-block-ford-motor-mount-engine-conversion-kit Note they state that it is only for cars that came with a Y-block even though we know there is an clearance advantage if the car came with a Six from the factory.
    bondojunkie and 61Lancerwagon like this.
  8. JeffB2
    JeffB2
    from Phoenix,AZ
    Post a picture from several angles of those "stock" GT mounts, the ones from a convertible are not the same as the ones listed in that link with the pictures, different part numbers.
  9. JeffB2
    JeffB2
    from Phoenix,AZ
    This shows the 302/5.0 in my '54 (55-56 have the same ch***is) when I first installed it, notice the distance from the valve cover to firewall with the Mustang mounts I listed in the link, I do not have a p***enger side view. Chili-size-platter-2-e1420170164660.jpg
    bondojunkie likes this.
  10. NC Customline
    NC Customline
    Since the plan is to by new anyway, I’ll get the ones you suggested. The mounts I have came out of mustang gt hardtop . Photo of mounts and back of head .
  11. JeffB2
    JeffB2
    from Phoenix,AZ
    Kustomline54 likes this.
  12. NC Customline
    NC Customline
    You definitely have more space behind the head than I do . I’ll try the new ones this weekend after slotting the frame holes .
  13. nosford
    nosford
    bondojunkie and JeffB2 like this.
  14. NC Customline
    NC Customline
    Did you use the Lokar shifter ? And throttle cable ?
  15. Dos Cincos
    Dos Cincos
    Both will work.
    However, I am only using the Lokar throttle cable because of my choice in accelerator pedal. It goes through the floor and was in the direct line of the Lokar shift rod. My dad wound up making one that worked for our setup.
    nosford and jimmy six like this.
  16. NC Customline
    NC Customline
    Dos
    Did you start off with 3on the tree and modify off that ?
  17. Dos Cincos
    Dos Cincos
    Nope - I actually swapped to a 56 auto column and steering wheel
  18. NC Customline
    NC Customline
    Genius, I am going to start looking for one . Has to be easier then installing the Lokar floor shifter.
  19. NC Customline
    NC Customline
    I ordered a column from speedway motors, be here next week.
  20. NC Customline
    NC Customline
    Guys
    How’s the reared hold up to the extra torque and power .
  21. Sgt. John
    Sgt. John
    from Virginia
    Good evening.I have a 56 Merc Monterey.I have a78 302 from a truck and I had to change the oil pan to a early 70s car type and used the B2220 and B2221 EARLY Mustang mounts with hedman headers and perfect fit and Engine fell slam on the mounts..you have to slot the frame pads..I use the OEM throttle bracket to Edelbrock intake
  22. NC Customline
    NC Customline
    Sgt
    Motor looks nice , I have new mounts coming in on Friday. I will slot the frame mount this weekend and drop it in again . I want to get everything to fit before I paint engine bay and start with wiring.
  23. Sgt. John
    Sgt. John
    from Virginia
    Thanks brother..I had a time to get it right
  24. nosford
    nosford
    I used the stock 55 automatic column, works fine but the gear position indicator is not accurate. Dosen't bother me so still using it. I had a cable throttle and pedal but didn't care for the way it felt. So using a pedal and linkage from a 70's F100 for the throttle. Mark
    Dos Cincos likes this.
  25. Dos Cincos
    Dos Cincos
    Same here with gear position lining up. I've got park and reverse but the rest are just by feel. The detents in the AOD are too close.
  26. NC Customline
    NC Customline
    I ordered this one from Speedway hope it works, seems like I saw somewhere that it should be 30” not 32” . I think I can work with an extra 2” one way or another.
  27. nosford
    nosford
    If you are using your stock steering box you will need to modify it by cutting off the shaft going to the steering wheel and installing a coupler to match up to that column. Wiring for the turn signals, brake lights, and possibly backup lights will need a GM style mating connector. The column drop where it hangs from the dash will be different as well. Not a huge deal but quite a bit of change required, not a bolt in by any means. If you are staying with a stock suspension and steering system you might consider doing a Borgson power steering box conversion at the same time instead of modifying the old stock steering box. Just FYI. Mark
  28. NC Customline
    NC Customline
    Mark
    Good info . Since this is build is one that I am adapting as I go nothing is off the table . At some point I just may do a mustang 2 front in , but if I can work everything out without doing that that would be great . The key for me now is get motor fit done , set to the side then work on engine bay and suspension.
  29. NC Customline
    NC Customline
    Mark
    Is this the right one ?
  30. JeffB2
    JeffB2
    from Phoenix,AZ
