1952-59 Ford 302 head hits firewall
Discussion in 'Off Topic Hot Rods & Customs' started by NC Customline, Mar 5, 2024.
  1. NC Customline
    NC Customline
    That looks interesting, just take a trip to lkq tomorrow
  2. NC Customline
    NC Customline
    Tried to cancel the steering column but it had shipped. So here it is . Looks good so i am going to use it . Here’s some pictures.
  3. nosford
    nosford
    Yes, that is the one a lot of people are using. It gives you a faster ratio steering without being over boosted and has none of the under the car hydraulic cylinders and lines like the original power steering does. The Borgson works well with the stock steering arms and suspension. If you are going to a Mustang 2 type set up then you will have a rack and pinion setup and no steering box.
  4. NC Customline
    NC Customline
    Guys
    Where does one get inner fender sheet metal, my battery box is eat up along with the sheet metal next to it . Dennis Carpenter has battery box “ or pan “ but not inner fender metal.
  5. Rustvelle SS
    Rustvelle SS
    Look for a local metal supply shop. Around here Home Depot, Lowes, Tractor Supply, etc. all have some small pieces of sheet metal but it's usually very thin gauge, you'll want at least 20 gauge, 18 gauge would be better. "The lower the number the thicker the metal"
    16 gauge would be too thick and tough to work with.
  6. NC Customline
    NC Customline
    Thanks I’ll check it out .
  7. jimmy six
    jimmy six
    Rear end strength depends on driving style. 5000 rpm sidestepping of the clutch with 10 psi tires can break the weakest part. If not using an overdrive the highest gear is 3.21. When I installed a 3 speed later automatic I wanted a higher rear ratio to have a lower rpm on the highway so I changed rearend but if I would have been happy with the 3.21’s I would have left the stock one.
  8. NC Customline
    NC Customline
    So I should be alright as a Saturday cruiser
    JeffB2 and jimmy six like this.
  9. NC Customline
    NC Customline
    I was worried about putting a 347 with AOD Trans up to the reared
  10. NC Customline
    NC Customline
    Ok guys it’s in ! Slotted the mounts , installed new on motor and like a glove (not an OJ glove) lol
    Kustomline54, JeffB2 and Dos Cincos like this.
  11. NC Customline
    NC Customline
    Guys , adjusted engine for level side to side worked on getting trans mount installed. Looks like transmission hits floor before I can get mount in so I’m going to drop it about an inch .
  12. Fairlane 62
    Fairlane 62
    Looks Like it belongs there. Good job.
  13. NC Customline
    NC Customline
    Fairlane
    Thanks , it’s been about 20years since I took on a project like this . Reminds me of how much I enjoyed working on cars before life got in the way .
    JeffB2 likes this.
  14. NC Customline
    NC Customline
    So the trans hits the tunnel , so I took matters into my hands and lowered the cross member by welding some plate to the bottom of it sticking out 1 1/2” on each side. Tomorrow I’m going to drill 2 holes on each side and bolt to bottom of frame. I will drill the 3 holes on each side after that .
  15. NC Customline
    NC Customline
    Thinking about doing electric water pump , any thoughts?
  16. NC Customline
    NC Customline
    So finished the trans mount came out pretty nice
    nosford, Dos Cincos and down-the-road like this.
  17. NC Customline
    NC Customline
    Did you guys have trouble with exhaust hitting steering box and spring purch ?
  18. NC Customline
    NC Customline
    Did you have any trouble with headers hitting spring pitch and steering box ?
  19. Dos Cincos
    Dos Cincos
    Which headers are you using? I had no issues using the Hedman headers in the FAQ
  20. NC Customline
    NC Customline
    I tried the stock headers from the donor 5.0 mustang
  21. ffr1222k
    ffr1222k
    I used the Hedman headers and they worked well. I made my motor mounts though. The Mustang fox body mounts did not work for me. I also tried the Falcon mounts but they sat too low. In hindsight I wish I had used the Falcon mounts and spaced them up 1/2" inch. My T5 transmission shifter hit the floor and I had to make a 1" tall metal box to cover it. I did cover the box in vinyl and it looks good. I also put a U in my seat so the shifter would work.
  22. NC Customline
    NC Customline
    Do the headman hug the motor?
  23. Dos Cincos
    Dos Cincos
    Hedman headers in mine.
  24. ffr1222k
    ffr1222k
    Where are you in NC?
    I am in the Cornelius area and you can come see my application if you are close.
    I think Dos Cincos picture is of the Hedman Headers.
  25. ffr1222k
    ffr1222k
  26. NC Customline
    NC Customline
    I’ll look at getting some headman headers , I may take you up on the visit. I’m in the Raleigh area
  27. Dos Cincos
    Dos Cincos
    I can't stress the solutions found in the FAQ's strongly enough. Many have been down the same road you find yourself on now and have mapped many of these issues out for us.
  28. NC Customline
    NC Customline
    Where do I find the FAQ’s ?
  29. Dos Cincos
    Dos Cincos
    It should be the very top post when looking at posts in this group. TON of info in there. Screenshot_20240722_170336_Samsung Internet.jpg
    down-the-road likes this.
  30. NC Customline
    NC Customline
    I will check it out , thanks for the info
    ffr1222k and Dos Cincos like this.
