1952-59 Ford 302 in my 53 Ford
Discussion in 'Off Topic Hot Rods & Customs' started by Rob Graham, Feb 22, 2011.
  1. Rob Graham
    Rob Graham
    from San Diego
    Hello fellow Ford lovers!
    I am new to the HAMB and resently relocated to San Diego.
    It's cool to see the Ford photos on the site.
    I have a fresh 302 with a rear sump pan that I am getting ready to install. Before i get to deep I have questions to anyone with the williness to steer me in the wright direction.
    1. Has anyone installed a 302 with the Jamco engine mount kit in there 53?
    2. Pro and Cons to the 302 swap?
    3. Radiator Clearance?
    4. Automatic Shifter Linkage vs. Headers?
    5. Gas peddel to throttel linkage for a Holly Carb?
    Sincerely
    Rob G.
  2. the-stig
    the-stig
    Welcome Rob, nice looking car. I can't answer your questions but I'm sure they will get answered soon. Great and knowledgeable group here.
  3. JeffB2
    JeffB2
    from Phoenix,AZ
    Mounts from www.speedwaymotors.com will save you around $50 over Jamco,check the main board for Complaints on Jamco and also Google, a member has a pictorial here of the swap and the mounts.,Radiator clearance,If your 302 is 1980 or later it has the long water pump and 50oz balancer,click on this link: www.jalopyjournal.com/forum/showthread.php?t=303600 scroll down to #5.The balancer mentioned(part# 91015365) these have both 3 and 4 bolt patterns for the pulleys and is available in 28 or 50oz balance and is short like the early balancers the early water pump is part#91015544.If you run a C4 or AOD Hedman header #88420 will fit.The easiest to install for gas pedals and TV cable(AOD) or kickdown(C4) ia LOKAR cable and bracket, for an oil pan you will want a Fox body dual sump to work with the '53 crossmember. You can use your stock transmission crossmember with a Energy Suspension trans mount #4-1104G,if you trial fit the engine and transmiision as a unit do a loose fit on the transmount then you will be able to mark the position where the engine mounts will go.
  4. 1956Ford
    1956Ford
    Welcome to HAMB. Please keep us posted on your project so I can watch and learn.
  5. mr. h
    mr. h
    ill let you know if its a good idea if mine will start and run next week.
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    Rob Graham,go to page 5 and look for this post by mr. h "53 rebuild" there are some good pics of the mounts,you may have an easier time of it as someone had put a Chevy in his and chopped up the frame a little also you will need the short oil filter,pm him for the part number.
  7. mr. h
    mr. h
    yea rob ive got tons of info for you. its taken forever but as soon as i get my lower radiator hose (dont ask) and driveshaft in ill be trying to start my rebuilt 302 for the first time. hopefully have her road worthy for lonestar roundup in a few weeks.
  8. carnut341
    carnut341
    Welcome from East Alton, Il. I really like your car
  9. Rob Graham
    Rob Graham
    from San Diego
    Gentlemen.
    I must say it is a pleasure to read your replyes. I gretly appreicate your advice.
    mr. h, keep me posted on your firing up your 302. Sounds like you have put a lot of time and effort into it, no doubt you will get her on the road.
    I am attempting to have mine done with in the next 7 weeks in time for Viva Las Vegas 11.
    Sincerely
    Rob G.
  10. dwaynerz
    dwaynerz
    welcome from bethalto il. sometimes wish i had at least "some" of the side trim. nice looking ride tho
  11. Rob Graham
    Rob Graham
    from San Diego
    Thanks dwaynerz, what's happening in Bethalto?
  12. dwaynerz
    dwaynerz
    not much. freezing drizzle this morning and big thunderstorm predicted for sunday. large hail, 60 mph winds and high near 70. spring and winter are fighting right now.
  13. Rob Graham
    Rob Graham
    from San Diego
    Sounds to be a rough one in you neck of the woods. Rained here Friday and Sat. in the 40 to upper 50. What motor are you running in your 53?
  14. dwaynerz
    dwaynerz
    302 w/aod. not sure the gearing, but knocked down over 25 mpg on a trip home from indy last yr. wifes v6 nitro cant even do that with all its fancy electronics. now she wants to drive mine to "save gas". uh huh.
