Technical 302 swap in 53 merc
Discussion in 'The Hokey Ass Message Board' started by Mr t type, Aug 11, 2023.
Tags:
  1. Mr t type
    Mr t type
    Hello, I am finally getting around to doing my 302 swap in my 53 mercury. Original components are long gone so updating seems to be the best option. Could you please share any links you have of this build and parts I may need?
  2. 62rebel
    62rebel
    This is not as difficult to do as it might seem; you should join the Shoebox thread/forum here and read through the various installs they've done. It can even be done with a front sump 302 if you don't mind slicing and welding the front crossmember.
    LOU WELLS likes this.
  3. Mr t type
    Mr t type
    I'll check it out, thanks
  4. Mr t type
    Mr t type
    These threads are not as easy to find as I thought
  5. guthriesmith
    guthriesmith
  6. I put a 302 in my 53 Ford, which is a very similar platform. There are some challenges with that install that has to be overcome. If you want specifics, PM me.
  7. Mr t type
    Mr t type
    Is this the pan I need?
    leadsled likes this.
  8. jimmy six
    jimmy six
    If its to make the 302 a rear sump and that mimics the flathead it’s probably what you want to do. 54-56 Ford guys need the front sump of a lot of Windsor Ford engines….good luck.
  9. martyk98
    martyk98
    from washington
    Too bad it's not a 54, I got all the help I needed from a fellow HAMBer. 52-53 are a little different with the flathead and front suspension.
  10. loveoftiki
    loveoftiki
    from Livonia,Mi
    I’ve not checked in awhile..but Butchs used to sell a whole kit…
  11. 51504bat
    51504bat
  12. bobss396
    bobss396
    Definitely go to the '52-'59 Ford Forum. They have a great FAQ section and lots of swaps like yours.
  13. saintpeewee
    saintpeewee
    I have a 53 Ford Customline and I’m rebuilding a 302 as well but not sure what trans to run. This sedan is just for cruising but if I could squeeze a C4 or AOD with very minimal fabrication that would be ideal. What are you running in your 53 Ford? Any large obstacles? Thanks!
  14. ^^^^ I put a 3.03 3 speed toploader in mine as I wanted to retain the manual column shift. A C4 has about the same bell housing area as the manual but is slightly larger in the main case. I used the motor mount kit from Butch's Cool stuff (the Shoebox Central kits are the same) and made my own transmission mount. The manual is close to the floor pan but does clear. I would bet that the motor will need to be dropped slightly for a C4 to clear. You have to have the motor back far enough for the rear sump oil pan to clear the drag link or notch the front crossmember and use a front sump pan. I went to an 8" Ford rear out of an early Maverick. Pretty much a bolt in swap.
  15. leadsled
    leadsled
    I did this about 20 years ago. The front sump pan from the 60s and 70s is a must. There is a small relief that goes into the left header for the steering. If the block is for a rear sump, dip stick is a problem.
    I used a C-4 trans, but today I would go AOD. There was a plate I had to make with an axial off-set but keep a regular 1960s C-4 trans mount. A drive shaft shop can redo the front U joint. Just use a tape measure for the measurements.
