Hot Rods 302 vs 350
Discussion in 'The Hokey Ass Message Board' started by AlaskanMatt, Oct 14, 2016.
  1. 19Eddy30
    19Eddy30
    from VA
    More information needed!!!
    What wrong with #7&8
    Do you need a rebuild as in freshened up ??
    Like reringed ?? Oil pump ,chain set ,gaskets new cam lifters or old ,cam bearings , rod& mains
    $600 or less , ( $300 ) not hard to re***emble ,
    You do the work .
    Or are you talking about bored over build
    $ 500 just to dip @ bore block
    $1,000 up to what ever you want
    Going from the Chevy to Ford ,
    Pretty much has been coverd
    Its Up to you ,
    Its olnly Time & money
  2. X38
    X38
    I have a SBF in a deuce and the pan rail is level with the ch***is rail. I have no idea why your is 6" higher (hard to tell in the pics.) Maybe the builder wasn't quite up to it.
    I live in a land where lots of hot rods of all years have SBF engines, both W & C. We built the C engines into 80's and they are very common. Use a short oil filter, easy. I think there are a lot of cry babies about SBF fitment. We have to deal with pedals, starter and steering all on the same side and seem to cope.
    As far as the question that started this thread, who gives a ****, it's got a cheap easy engine already, rebuild it or get a fresh crate and move on.
    BTW, where is the OP?
  3. falcongeorge
    falcongeorge
    from BC
    Cleveland would make more sense than the 302, at least then you would actually be gaining something over the chevy.
  4. tb33anda3rd
    tb33anda3rd
    good traditional catch/edit.
  5. mike bowling
    mike bowling
    Yeah, you don't want a 302 Ford in your hot rod, people keep asking you "why?"
    And they don't know it but they answered their own question. ( Why not?)
    Only drawback I've found is parts are 10- 20% more for a SBF.
    ( and you CAN get a short water pump and pulley set to reduce the length by 2 1/2 inches Also a short oil filter- Fram PH16 )
