305
Discussion in 'The Hokey Ass Message Board' started by 52lomofo, Jan 14, 2011.
  1. 52lomofo
    52lomofo
    what the differance of a 305 from 78 nova and a 305 from 78 buick ??any??what auto ****** would they come with???:)
  2. MBog
    MBog
    Yur makin us look bad...a 305 is a 305!
  3. Rudebaker
    Rudebaker
    from Illinois
    In the late 70's GM was putting Chevy engines in Buicks and Oldsmobiles and Olds engines in Pontiacs. They were putting Buick 231 V-6's in almost everything and had 4 distinct 350's for Chevy, Buick, Olds and Pontiac so I'd say for anyone not "of age" back then it's not a dumb question. In the case of the 305 though they were the same engines, if it had an automatic the trans could be a TH200 (JUNK), a TH250 (almost as bad) or a TH350. There didn't seem to be any logic to what got what trans back then and all 3 are very similar in outward appearance. There are some differences to let you ID the trans but I don't recall what they are.
  4. onlychevrolets
    onlychevrolets
    The TH250 looks like a TH350 but it has a band adjustment bolt just behind the bell housing, Don't let some one tell you it's a 350 if it has that. A 350 band is only used for intermediate (manual second), it uses three clutches behind the pump for intermediate gear , while the 250 uses that small band.
  5. 53sled
    53sled
    from KCMO
  6. gtkane
    gtkane
    Don't forget that internally the transmissions are the same, but a BOP trans will not bolt up to a chevy motor, and vice-versa.
    The exception is the 200R4 trans, which had dual bolt patterns on the bell housing.
  7. David Chandler
    David Chandler
    I worked with a man who bought a full size chevy wagon. He moaned over and over that it had a Pontiac "305" in it. It's the only time I've heard of one. But another guy bought a new Buick and was sore as hell that it had a Chevy under the hood.
    I bought the driveline out of a 73 Omega. 250 I6 with a turbo 375 behind it. Strange things were going on back then. I think GM was trying to standardize their engines by having a "Corporate" line, rather than individual brands. Which went totally against their marketing practices in the past.
  8. Garagedog00
    Garagedog00
    from NY
    Thats a real ripper you got there
  9. pdq67
    pdq67
    ID the ****** by hunting up a ****** pan site that has pic's of all of them.
    Easy way to do this.
    pdq67
  10. moefuzz
    moefuzz
    There's no difference, they're both poorly designed, under powered, short lifespan oil burning engines done in true GM style.
  11. 56sedandelivery
    56sedandelivery
    "Corporate" 305 motor (a SBC). The trans could be almost anything as mentioned above. BUT, the metric 200 is finding favor a****st the stock cl*** drag racers, and they can be built to handle power. Butch/56sedandelivery.
  12. burnin53
    burnin53
    from cuba,n.y.
    Some T-350's came with both patterns,too.I happen to have one in my pick-up.
  13. onlychevrolets
    onlychevrolets
    I happen to have one on my building fixture...
  14. The Shocker
    The Shocker
    Seems like it was a one year only deal from what i heard on the dual pattern thing.Its funny how even though GM used several different transmissions in the late 70's early 80's they kept the other stuff the same .I once had a 307 Olds with a 2004R (overdrive with the lockup convertor) that went to ****.I got a BOPC pattern T350(non lockup) from a wrecking yard to replace it.It bolted right up and the flexplate had another set of holes for the different convertor pattern .Even the driveshaft was the same length and the yoke had the same spline .All i had to do was silde the crossmember forward a bit to make up for the T350's further forward rear mounting point and drill new holes in the frame.Was one of the easiest conversions i have ever done .Even the cooling lines were the same size ,i just had to rebend them a bit to make them line up ...
  15. junkyardjeff
    junkyardjeff
    GM did some weird stuff back then as I have seen the TH350 behind V6s and the smaller trans behind V8s.
  16. skidsteer
    skidsteer
    I bought a '78 Buick Skylark brand new. It came with a disclaimer that the V-8 engine could have been from another GM division, and could have been manufactured in Canada.
