307 chevy fans ?
Discussion in 'The Hokey Ass Message Board' started by 31Vicky with a hemi, Jun 9, 2012.
  1. 50ChevyFrank
    50ChevyFrank
    There was a 307 in the 50 Chevy Pickup I bought in '99. Ran good. Purely stock except for dual exhaust. No complaints from me - but I wasn't trying to race it or anything like that.
  2. Deuces
    Deuces
    You gave up a droptop Chevelle for the Camaro???:eek:
  3. And what if you could get + 0.030,40 or 60 pistons for 137.00 plus shipping ?
    http://www.ebay.com/itm/380466026069?redirect=mobile
    Does that sweeten the deal?
    How about the whole damn kit with oversized pistons for 285.00
    http://www.northernautoparts.com/ProductDetail.cfm?ProductId=627
  4. Junior Stock
    Junior Stock
    So have you run your little monster motor yet?
  5. Deuces
    Deuces
  6. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    My 307 developed a bad knock the other day, started it up and within 5 minutes it sounded like a jack hammer! :eek: It was a good motor, was in my buddys truck for a while, then I put it in my drag car and got about 60 p***es out of it so I cant complain about a free motor. The crank isnt hurt so im gonna do like porkn****** said, take the 307 crank and put in a 350 block. ;)
  7. Deuces
    Deuces
    [QUOTE="T'RANTULA";8166446]My 307 developed a bad knock the other day, started it up and within 5 minutes it sounded like a jack hammer! :eek: It was a good motor, was in my buddys truck for a while, then I put it in my drag car and got about 60 p***es out of it so I cant complain about a free motor. The crank isnt hurt so im gonna do like porkn****** said, take the 307 crank and put in a 350 block. ;)[/QUOTE]
    How do you know the crank ain't hurt???...
    Did you dis-***emble the motor and mic the journals???....
    Let's see some pictures!...
  8. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I aint exactly taken it apart yet, but its more or less an ***umption that its ok. When I get it apart ill post pics.. Dont bust my chops too bad Deuces! :eek:
  9. Deuces
    Deuces
    Ok, I won't...;)
  10. "T'RANTULA"
    "T'RANTULA"
    from Ohio
    I will admit my knowledge about building engines couldent fill a thimble. But a person has to start some were right? :)
  11. falcongeorge
    falcongeorge
    from BC
    Hmmmm. yea, nominally .016 in the hole?? Yes that does, actually. A set of lightly milled Vortecs with a ghetto grind and some pocket work...Yea, that sweetens the pot alot.
  12. falcongeorge
    falcongeorge
    from BC
    Hate to break it to you, but odds are...
  13. [QUOTE="T'RANTULA";8166446]My 307 developed a bad knock the other day, started it up and within 5 minutes it sounded like a jack hammer! :eek: It was a good motor, was in my buddys truck for a while, then I put it in my drag car and got about 60 p***es out of it so I cant complain about a free motor. The crank isnt hurt so im gonna do like porkn****** said, take the 307 crank and put in a 350 block. ;)[/QUOTE]
    Jack hammer noises pretty much guarantee you the crank needs work.
    How loud and how long will determine how much work to be true or a mailbox post.
  14. Johnny Gee
    Johnny Gee
    from Downey, Ca
    That's OK, then he can have the rod journals turned down for small journal rods ;).
  15. Truckedup
    Truckedup
    I had 307 parts advertised here on the Hamb,standard crank and blocks,a complete engine.No one wanted them here or Craigs list. After 6 months of the stuff being the way,I s****ped if all.
  16. fast30coupe
    fast30coupe
    from Illinois
    got one for sale in the cl***ifieds if anyone's int intrested
  17. 54sled
    54sled
    Running the 307 in my 54 ford mainline,small
    Cam,intake and carb,4.10 gears,fast out of the hole,just put together a tri power set up with rochesters 2gs on it,we will see how it works!
  18. 26 roadster
    26 roadster
    I wish I had Known they were so good..................I have s****ed a few dozen because you can't give them away.
  19. Deuces
    Deuces
    That was a few dozen with 327 crankshafts..
    You sir should be horse whipped...;)
  20. Well if you get a few dozen more,
    let me know. Actually probably worth the trip down for just a couple if they run with good compression.
  21. Well nobody wants them.
    Several reasons for that, there is a stigma attached to them because the factory screwed the pooch when they made them. What they did wrong was use ****y quality cams, nylon gears and huge combustion chambered heads. However most gear heads change those things around first on any hop up. But because its a 307 and Everyone has "treefidy" on the brain , they come out in good working order never to be thought of again. The other thing was chevy never used it in anything performance related, therefore it never will be any good.
    Wow cool 283, fast too.
    Whoa *****en 327 , screamer.
    Eeew a 307 , slug, dog, grandma motor, junk, boat anchor, s****
    I went round and round with a guy over here about his 383. Blah blah this, blah blah that yadda yadda the other thing and back again. I listened politely and at the end of that I ask how much did it cost and how much power. He says 4,000 and 400.hp. I say fair enough and I'm sure it will run hard. But you're spending 10.00 per 1 HP or 10:1 dollar HP ratio, not bad in the big picture. Now we were talking about this standing next to my blown hemi so there's no need to think I'm a cheap skate but .....
    I said look at this, a running 307 - free . 305 heads free. Cam, and gaskets less than 200
    Should be 300-325 HP. My ratio 0.60:1 or 60 cents per 1 HP.
    $0.60 per 1 HP compared to $10.00 per 1 HP is a pretty easy choice to make. Unless that extra 75-100 HP is worth $ 3800.00
    Let's say you spend 300 for a good 307 engine ( insane) and 100 on 305 heads ( insane too) and the 200 for cam and gaskets. That's 600.00- hell call it 1000.00 .
    Now the ratio is $3.00:1 HP still a no brainer.
    All of that works out financially when you find one of those lowly 307s being discharged from duty solely because its a 307. If its tired and needs plenty or if you are planning a total rebuild of a worn out engine, or build up of a ultra high performance machine, the dollar to HP ratio gets flipped around a bit to far on the 307 and better choices are there.
  22. 54sled
    54sled
    Well said 31 vicky!
  23. falcongeorge
    falcongeorge
    from BC
    Good idea.
  24. falcongeorge
    falcongeorge
    from BC
    Rather than something to brag about, s****ping 307s left right and center is a pretty solid indicator that someone doesn't know **** about sbc's. Seriously. You do realize you just pitched a truckload of large-journal 327 cranks, right? And if any of those 307s came from trucks, at least a few of them would have been steel.:rolleyes:;) Way to go...
  25. Tin Can
    Tin Can
    I have one in my 53 that I have been working on for a while. People wonder why I put a 307 in my custom when there is a 350 on a stand next to it. I do not think they will be wondering when they hear it run now that it is running. It sounds gooooood!
  26. For sale 307 crank - ........ EEEEEW
    For sale large journal
    327 crank - .......... Cool
    307 truck engine. .......... Eeeeeew
    327 forged crank .......... very cool , I want two please.
    It funny how many gear heads on all the internet forums just beat the 307 like a red headed step child but just would kill for a forged 327 crank. 307 is the worst engine ever made by chevy , complete garbage blah blah blah.
    But I'm going to shut up now, seems the price of 307s on CL just tripled by the latest listings.
  27. falcongeorge
    falcongeorge
    from BC
    Oops! Oh oh. Yea, 307s are ****, man, you dont want one of those. Now that you mention it, so are small journal 327s. Steer clear of those too. Get a 350!:rolleyes::p
  28. Rocky
    Rocky
    Classified Editor
    I bought a bone-stock 72 nova with a 307-muncie 4 speed..only modification was a hurst shifter.
    I found a free 350 HP cam, and a factory 350 Q-jet setup for it...installed a Zoom clutch and new dual exhaust with gl***pacs.
    It still gave me 18 MPG on the hiway and ran pretty hard. Was a lotta clean, cheap fun.
  29. 26 roadster
    26 roadster
    I kept the 3.25 cast cranks...............and made a few 350/327's
  30. Speed Gems
    Speed Gems
    Don't feel too bad none of those cranks were steel.
