Technical 30s Ford Ignition Resistor
Discussion in 'The Hokey Ass Message Board' started by 4wd1936, Mar 9, 2019.
  1. 4wd1936
    4wd1936
    from NY
    Does the original ignition system on a 37-37 Ford really need the resistor under the dash on the firewall. We have one here that simply will not start unless that is byp***ed and this is the third resistor. Is it possible that these after market(off shore I'm sure) resistors are simply junk. Test light is bright on power, rather dim on outlet. Thanks
  2. sdluck
    sdluck
    What are the voltages before and after the coil on the bat side
