31 5W Coupe Build up
Discussion in 'The Hokey Ass Message Board' started by Chopperman, Oct 22, 2006.
  1. 39delux
    39delux
    Thanks. I'll do that when I get this truck done. That's a beautiful engine.
    Tom
  2. Eddie's chop shop
    Eddie's chop shop
    My motor is ugly....
    Yours looks sweeeetttt!
    (make that engine, since I read a post about this)
  3. deedster
    deedster
    I like your ( logic ) plan...That reminds me of Gray Baskerville saying:
    ...................." Use your walnut instead of your wallet " .....................
  4. Chopperman
    Chopperman
    I think your SB will run laps around it. The hemi needs a rebuild, but i figure I'll try it and if it runs it's all good. If it smokes, well that just adds character. If it doesn't run, it's rebuild time.
    It's like a triumph with 8 cyl. LOL
  5. Chopperman
    Chopperman
    Exhaust arrived.
    Matt at lake headers is THE MAN... AWESOME work at a VERY fair price
    http://www.lakeheaders.com/
    Hoping to have the sub frame and body mounts completed by eond of the weekend.
  6. Eddie's chop shop
    Eddie's chop shop
    That's the same boat I am in. I know this motor runs, since I fired it up once before I yanked it 2 1/2 yrs ago, although I have no idea how tight it is may smoke like a chimney. I figure run it till it blows and build something BIG. 572 big block 871 blower?
  7. Chopperman
    Chopperman
    A blower would be SIACKK. That intake would be WAYYYYY over your roofline.
    You gonna drive that biatch over this weekend or what ? Got a nice cold beer waiting for you :D
  8. Eddie's chop shop
    Eddie's chop shop
    Hopefully will fire it and drive it around the block on Sunday. Still need lights and insurance before it hits the road. I may have a problem before I get very far though. The hydraulic throwout bearing seems to have a little too much preload without any spacers in it... not sure if its gonna slip.
  9. Eddie's chop shop
    Eddie's chop shop
    I've got a blower on the vette, and now I just figure everything should have one....
  10. Eddie's chop shop
    Eddie's chop shop
    Pipes look good, are you gonna straight pipe em?
  11. marx
    marx
    i've got to ditto that. Matt is one straight-up dude, and his craftsmanship is first rate! super-solid workmanship. i can't say enough about how much i like the headers he made for my sedan....and a crazy good deal by anybody's standards!
    i just wanted to add that, to my current favorite thread.....
  12. Chopperman
    Chopperman
    I ordered baffles so we will see. I can go either way
  13. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
    It will run. It came out of a running car. All I did was get the inch of dirt and grease off it. Will it smoke? I don't know. I was told it wouldn't. Like you said, it adds character. You will have this thing to Paso this year. Did you get your reg sent in? Got a room booked yet? EVILT
  14. Chopperman
    Chopperman
    When ? Where ? How ? I'm a noob my brotha. Got a link
    I'm not stressed about the engine, I'm sure it will run. I saw some pretty interesting things inside that raised my eyebrows. It's just a matter of how much I'm willing to throw at it.
  15. -Brent-
    -Brent-
    I love this build-up. Much different than the Pirate builds but I love this all the same.
  16. Chopperman
    Chopperman
    Started working on the sub frame. Taking a break for lunch so I'll post up a couple pics.
  17. Chopperman
    Chopperman
    Closing out the day. Doesn't seem like I got anything done, but I did... I'm to the point in the build now where it really doesn't matter what I do, the car doesn't take on any dramatic changes so progress seems slow.
  18. Littleman
    Littleman
    Alliance Member
    from OHIO, USA
    Looking good Chopperman!!!!!!!!!!!!!.........keep up the great work.....its all coming together......Littleman
  19. Sloan
    Sloan
    Chopperman how tall are you?
  20. Chopperman
    Chopperman
    5' 10".... It's tight in there.
  21. Bear Metal Kustoms
    Bear Metal Kustoms
    Alliance Vendor
  22. chevnut
    chevnut
    from Corona, Ca
    Awesome Chopperman, Awesome.
  23. tikidiablo
    tikidiablo
    from so cal
    looking great. would love to get stuff done at the pace you have set. I'm close though.
  24. bcharlton
    bcharlton
    from Buffalo NY
    Chopperman:
    I am planning on running lake pipes only in my 31 Olds 5 window coupe. I look forward to "hearing" how the baffals work out. I do not want to run strait pipes but I will if I continue to get pulled over by the men in blue. Please let me know.
    Great car/great post
    Brian
  25. DeuceDog
    DeuceDog
    from Breese, IL
    What a cool thread...Looks very nice. Keep up the posts, all most there.
    DD
  26. 39delux
    39delux
    It may seem like it's going slow to you but I just got home from Daytona and it looks like you got a lot done. Love the headers.
  27. Chopperman
    Chopperman
    Decided to take a break from the sub frame and work on the cooling system.
    I ordered some adapters from hot heads, only problem is that unless you run their motor mounts, timing cover, and cam they don't fit. So I had to modify the stock timing cover, adapters and add soem pump spacers to get it all to work right.
    I also picked up a 65-66 Mustang 3 row and it looks like it is going to fit my A grill and frame pretty good. I'm going to stick the shell way out in front and LOW. I will also have to run the lower hose in between the axle and the spring. No big deal though, there about 4" in there.
    Radiator is sitting about where it will go
  28. K13
    K13
    Looking good Chopperman. What did you use for the rubber portion of your engine mounts?
  29. 53dodgekustom
    53dodgekustom
    WOW! That A grill looks bad *** in there. I love it.
  30. Chopperman
    Chopperman
    OK got the radiator mounted and got alot done to the beat up A shell I'm using. It had alot of rips and was generaly F-ed up.
    The shell is just resting in the last pic.
