Hot Rods 31 A pickup using tudor doors
Discussion in 'The Hokey Ass Message Board' started by ABONES, Aug 8, 2015.
  1. Any body build a 30-31 Model A pickup cab using tudor doors. Doors are only a little over an inch longer. I realize the subrails and roof panels over the doors would need to be extended. Pics?
  2. flatford39
    flatford39
    You got something else happening if the doors don't fit. 30 31 tudor doors are identical to 30 31 pick up doors. Do you actually have a pick up cab or is it a cut down sedan??
    Reds 29 likes this.
  3. Pickup and coupe are the same. Tudor doors are longer. I am just wondering if any body has used tudor doors and wondering what the cab would look like using the longer doors.
  4. Midnight Rider
    Midnight Rider
    from Australia
    As flatford 39 says, Tudor and Pickup are same doors. Coupe and Sedan are the short ones. Easiest way to extend cab is add a bit in original back near door pillars. Hope this helps.
  5. Midnight Rider
    Midnight Rider
    from Australia
    Just to clarify, when I said Sedan I meant 4 door Sedan, wood frame doors.
  6. My bad. I was thinking coupe and pickup were the same and tudor doors were longer. Sorry stupid question.
