31 Almost done!
Discussion in 'The Hokey Ass Message Board' started by JustplainJ, Aug 6, 2007.
  1. JustplainJ
    JustplainJ
    from so.cal.
    After 2.5 months 31 just about done! let me know what you guy's think or any suggestions. bishop welding brings up a good point you guy's give me your thoughts on bump steer, I really wanted to do this car with cowl steering so I know the geometry is off but how bad can it be? is the car going rip the steering wheel out of my hands or move inch's what can I expect? like to hear from someone who has reversed an f 150 box Thu the cowl. also the pic's make the hood line look off but it must be the way car sits on downward slope coming out of my shop and the way I took pic's. the back lower extension is not finished at rear of tire yet, and I'm also thinking of an extension under doors the length of the body to look like it has a belly pan. keep your thoughts coming thanks for all the input.
  2. 52 HenryJ
    52 HenryJ
    wow very nice!
  3. Bishop Welding
    Bishop Welding
    from USA
    I like it. I really like it a lot.
    You may end up with some bump-steer with the steering geometry set up the way it is.
    The rest of the car is dead on.
  4. Dahlhjelm
    Dahlhjelm
    Looking good!
    Do as bishop suggested and it'll be perfect.
    /Eric.
  5. alleyoop
    alleyoop
    Nice work keep it up i like the dash very nice as with all the work so far, I think i would do some thing with the fire wall and rear deck mabbe roll under some but i no you are not done yet. nice ,I see all the little things you have done that takes a lot of time and thught that is what makes a good hot rod and yours will be a true hot rod. nice to see for a change. alley ;)
  6. Sawracer
    Sawracer
    from socal
    Nice car. Good luck with those seats though.
  7. I go pogo
    I go pogo
    I like the hood line just as it is. Good project.
    Pogo
  8. pasadenahotrod
    pasadenahotrod
    from Texas
    That's a good lookin' ride!!
    Regarding the extended tailpiece issue, I think it might be a visual plus to extend the lowered edge forward at least to behind the tire by an inch or three. This will pretty much eliminate that severe edge that's hanging out there.
    The hood line is just a smidge off since the leading and trailing edges of the hood don't match the vertical edge of either the radiator shell or the cowl. The ultimate solution might be to make up a one-piece hood top without the bead on the lower edge which aligns with rad shell and then straight back to the cowl to an aligned edge there. It will be lower than "normal" at the back bust will flow better with the shell. The "problem" even without the bead is that drooping lower edge and the "crooked" fit to each end.
    BUT, all the same, it is a nice ride and I wouldn't do the extra work if I didn't see anything wrong. However, you did ask, didn't you? ;)
  9. Bishop Welding
    Bishop Welding
    from USA
    Stand on the frame horns and bounce a little. That'll kinda give you an idea what the steering wheel will be doing. Until you drive it you won't know exactly how bas it is. It MAY not be too bad because your pittman arm is pretty long and may compensate some. I had a car with some considerable bumpsteer and it got really old, really really fast.
    If you're like me, it'll be a long time before it gets corrected once the car is drivable. I'd reccommend ironing the problem out now while it's still in fabrication stage in case you have to make any other adjustments around it. I can tell by the rest of the car that whatever you figure out it'll be right.
    I really like this car.
  10. TommyLeDouche
    TommyLeDouche
    I wouldn't know what to say, it looks great as is!
  11. Lee Martin
    Lee Martin
  12. wvenfield
    wvenfield
    Really nice. Now when are you going to finish it? ;)
  13. nailheadroadster
    nailheadroadster
    Damn sweet!!! But I gotta ask... 2 1/2 months???? Is that from the start to what we see?? You need to get off yer *** and get to work ya slacker!!!! Doesn't anyone in Cali have a job they have to go to? GEEZ!
  14. Ryan
    Ryan
    ADMINISTRATOR
    Excellent looking little roadster...
  15. SinisterCustom
    SinisterCustom
    Is the motor mounted solid?? The header looks very close to the drag link, may hit once the engine 'torques' over......I'd say move the shell up as well, but look at the old pics of regular guys hotrods "back in the day"....many of them had quirky details that set them apart....kinda makes 'em cool..(to me anyway)......either way.....you've got a nice car!
  16. converseandbowlingshirts
    from Eugene, OR
    The only thing I can give is praise...if you finish it like you say, it's going to be so correct.
  17. JustplainJ
    JustplainJ
    from so.cal.
    for all the guy's wondering how I got done so fast here are some of the tools I have in shop. not pictured are mill, lathe, mig, tig, slip roller and large mittler bros. bead roller, finger brake, hyd. shear. a**** others. thanks for all the pos. replies
  18. TMoney
    TMoney
    Amazing job in such a short period of time!
  19. Preacher
    Preacher
    Love it, looks like a great ride.
  20. lehr
    lehr
    The hell with that car look at them there tools... oh yea nice car too. Pat
  21. qzjrd5
    qzjrd5
    from Troy, MI
    Love it man. The car has a great stance also!
  22. ss34coupe
    ss34coupe
    great car and great shop!!
  23. JustplainJ
    JustplainJ
    from so.cal.
    here's what I started with. now has 40 rear end, 39 trans,59 ab Flathead, 37 steering wheel and column,32 grill shell and 31 brooksville body.
  24. JustplainJ
    JustplainJ
    from so.cal.
    ALRIGHT, the gas tank is done so I'm going to stare at it for a week the tear it apart for paint/powdercoat. also found 682J headlights.
  25. MIKE-3137
    MIKE-3137
    Nice!...Model A roadsters rule...but i'm biased.
  26. budd
    budd
    nice job, have you ever made quarters from scratch?, i have a 30 4-door that i'd give a try at turning into a roadster.
  27. wyoming
    wyoming
    from My house
    aint that cheating jk im jealous
