Projects 31 Chevy death trap
Discussion in 'Traditional Hot Rods' started by armymike, Mar 28, 2022.
  1. armymike
    armymike
    from Fullerton
  2. hrm2k
    hrm2k
    Scrub Line..........lots of people do not think that matters............until they get a flat
  3. dwollam
    dwollam
    Wow! Like the stack of spacer nuts on the tie rod/steering arm! :(
    Dave
  4. fiftyv8
    fiftyv8
    from CO & WA
    There is low and then there is too low...
  5. New definition of dropped axle. Ridiculous.
  6. pprather
    pprather
    Well, this thread has the right ***le!
    armymike, Blue One, mad mikey and 3 others like this.
  7. Hollywood-East
    Hollywood-East
    That much leverage w/disc brakes, an a dropped axle... A lot!
    Single leaf...!
    Be like front wheel hop..
    Spoggie, Stogy and Big mike 1968 like this.
  8. Max Gearhead
    Max Gearhead
    from Wisconsin
  9. Un friggin believable , no common sense what so ****in ever .. Truck should be pulled off the road and who ever installed that axle locked up for awhile . No regard for their own safety or the public's safety. Give hot rodders a bad name
  10. Doublepumper
    Doublepumper
    from OR-WA, USA
    Yikes! If that wasn't done to make a roller, hope you're fixing all that. Can it even be steered with the tires sunk into the fenders that far?o_O
    mad mikey, Stogy and Big mike 1968 like this.
  11. This thread reads like a Volvo owners forum.
  12. 1971BB427
    1971BB427
    from Oregon
    With that stack of old hardware spacing the tie rod to the flat steering arms, the ends will have plenty of leverage to twist on the flat steering arms and get a good death wobble going if it hits a bump or pothole. That is if hitting a hole doesn't bottom it out and tear things loose anyway!
    Spoggie, mad mikey and Stogy like this.
  13. Had a friend with a 55 chev pick up with this sort of set up , 7 inch drop , everything below the scrub line . Blew a tire on the freeway 70mph skidded across 4 lanes of traffic, managed to keep it off the concrete center medium ,skidded back across 4 lanes of traffic and dug in on the dirt shoulder ,
    Lucky to be alive , and not cause any other accidents .
    Had it towed home and his fix was a skid plate welded under the truck .
    What a knob ....
  14. Jalopy Joker
    Jalopy Joker
    - seems like there is a thread here that states the stance is everything - some say that safety is for sissies - just going out the driveway would be a challenge - who has a pack of unfiltered smokes to do some clearance checking with?
  15. Bandit Billy
    Bandit Billy
    I'd use Lucky's, cuz you'll need some luck driving that.
    Cosmo49, Blues4U, rust&patina and 8 others like this.
  16. Stogy
    Stogy
    Is it yours? Did you just buy it? It certainly is good for negotiations...
    armymike, mad mikey and hrm2k like this.
  17. Stogy
    Stogy
    I guess there are several ways to achieve said stance in a more mechanically certifiable manner however this fails to achieve that...
    I sure hope the original poster chimes in as what's the point here.
    mad mikey and wood remover like this.
  18. cfmvw
    cfmvw
    Just the amount of drop on that axle alone is scary... that really got stretched too much.
    wood remover and Stogy like this.
  19. Dont know who would have bent/stretched this axle this much , but hate to think if something broke , if it may come back to haunt them !!!!
  20. Your friends and acquaintances are only your friends and acquaintances.
    Until they can sue you !!!
    reagen and hrm2k like this.
  21. Nothing personal , just business
    Moedog07, Stogy and hrm2k like this.
  22. Unfortunately we will all be painted with the same stick when he does wipe out a family out
    I sure hope whoever took the picture has enough sense to point out just how unsafe this front end is .
    mad mikey, Guy Patterson and Stogy like this.
  23. I went to look at a shoebox Ford a while ago , clean looking car , had a steering rack installed in a frame that sat below the scrub line .
    took it for a drive and hit a bump and the rack hit the road the car jerked violently!
    Made a left turn and the rack hit again and I pretty much did a u-turn
    End of road test . Owner did not understand why I didn’t even want to negotiate.
    mad mikey, hrm2k and Stogy like this.
  24. twenty8
    twenty8
    Hey @armymike , your profile says you own a '31 Chevy truck. Please tell us it's not the one in the pic.
    If it is, I hope that you just got it, and that you are going to fix it before you drive it.
  25. Guy Patterson
    Guy Patterson
    I am still trying to figure out how you turn in that truck?
    Stogy likes this.
  26. 282doorUK
    282doorUK
    Early Chevy manuals make a point of saying that on no account should heat be used when straightening their front axles.
    So presumably heat has an adverse effect on the metal, is it possible to drop a cold axle even a tiny bit?
    That much drop took a whole lot of heat!
  27. adam401
    adam401
    Everything aside, im suprised they were able to maintain that much track width up front with that big of a drop. The wheels dont look like they have a crazy offset or anything and the tire is still right out near the edge of the fender.
    mad mikey, Tman, Stogy and 1 other person like this.
  28. Stogy
    Stogy
    This Thread is starting to remind me of the 4dr Vicky Thread, post a Thread with no words, it'll be 4 pages of wtf's and no sign of the original poster but we shall see...4 posts since 2013...hmmm...I echo @twenty8, @armymike what is beyond the shock value here, a fix?
  29. MCjim
    MCjim
    from soCal
    Perhaps he was expecting a more positive response...
    That said, the form follows function line of thinking, is often lacking trying to be "period correct", and is replaced with a "it is better to look good, than to feel good" mentality.
    Stogy likes this.
  30. Stogy
    Stogy
    My thoughts are he called it a Death Trap himself via the ***le backed up with not one iota of what he was wanting out of this...we are not mind readers here. I hope he reads this thread and does respond. It may save lives. If he's offended, and doesn't respond, I hope at a minimum he realizes what he called it is in fact what it is and he takes it in to a reputable shop and has it thoroughly looked over for safety as whomever is responsible needs a knowledgeable ***essment of their work and a fix executed...
    mad mikey and El Mirage Garage like this.
